Automating Exports
Pretty darn clever way around that miserable ODBC program. Can I get you and
Wayne to do my Federal Tax Return this year? : ) Les
> -----Original Message-----
> From: Troy Funte [SMTP:tfunte@...]
> Sent: Monday, December 10, 2001 10:33 AM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Automating Exports
> When I do multiple exports, I call them one by one from a main export.p
> program using the "run subexport.p" program. I also added a button to
> STOP the process, just in case. It helps to add a Target line to your
> shortcut: n:\vantage, so that you don't have to add the path to each of
> your run statements.
> I use the .csv files by linking them in Access, and then creating a query
> from them. That way I can use them in Crystal reports or Access reports.
> Each time the files are exported again, the links are automatically
> updated with the new data. I've found that adding fields to Vantage
> Reports this way, rather than through ODBC, eliminates having to have ODBC
> on those workstations.
> I'd love to hear ideas from others on what can be done using these
> exports.
> (And thanks to Wayne Cox for originally communicating the idea to me.)
> Troy Funte
> Liberty Electronics
> From: Les Tingley
> Sent: Monday, December 10, 2001 10:30 AM
> Subject: RE: [Vantage] Automating Exports
> Thanks Troy,
> I modified your code, and it worked great in my 5.1 test environment.
> I'll now attempt to apply this to suit my needs.
> Les
> > Sent: Monday, December 10, 2001 9:43 AM
> > Les,
> > Below is the text of the Program. Change the company name to your
> > company.(If you cut and paste from Vantage Export Utility, you will
> need
> > to put your company name here as well. The export uses a variable
> > "cur-comp".) Save the text in a file with a .p extension. Put the file
> in
> > your Vantage folder (or Vantage/ud). Then create a shortcut on your
> > desktop with the following command line:
> > N:\progress\bin\prowin32.exe -db n:\vantage\db\vantage.db -N TCP -S
> > servicename -H servername -p n:\vantage\export.p
> > N is the mapped drive to Vantage.
> > servicename is usually epic50 for Vantage 5.0.
> > servername is the name of your server with Vantage.
> > If you want to use the Procedure Editor to edit and work with your
> > program, you will need to find a way to connect to the database so
> that
> > you can run it. I usually click Edit/Insert Field, which then prompts
> me
> > to connect to the database. After connecting, I click cancel and then
> > click F2 t run the program to test it. The Help in Procedure Editor
> can
> > give you all the fancy stuff like variables, messages, calling other
> > programs, etc.
> > Feel free to ask more questions.
> > Troy Funte
> > Liberty Electronics
> > /* begin export program */
> > output to c:vntgwork\job.csv.
> > export delimiter "," "JobNum" "MtlSeq" "Partum" "Description"
> > "RequiredQty" "IssuedQty" "PartNum" "PartDescription".
> > for each JobMtl Where JobMtl.Company = '100'
> > and JobMtl.IssuedComplete = no
> > and JobMtl.JobComplete = no no-lock,
> > each JobHead Where JobHead.Company = JobMtl.Company
> > and JobHead.JobNum = JobMtl.JobNum
> > and JobHead.JobReleased = yes and JobHead.JobClosed = no
> > and JobMtl.RequiredQty > JobMtl.IssuedQty
> > By JobMtl.JobNum:
> > JobMtl.JobNum
> > JobMtl.MtlSeq
> > JobMtl.PartNum
> > JobMtl.Description
> > JobMtl.RequiredQty
> > JobMtl.IssuedQty
> > JobHead.PartNum
> > JobHead.PartDescription.
> > end.
> > output close.
> > message " Records exported for Job.csv Table.".
> > /* end of export */
> > From: Les Tingley
> > Sent: Monday, December 10, 2001 8:58 AM
> > Hi Troy,
> > Yes, Please send me the samples.
> > Thanks,
> > Les Tingley
> > MIS Director
> > Decorated Products
> > > Sent: Monday, December 10, 2001 8:51 AM
> > > Les,
> > > We had been exporting data nightly in Vantage for months using
> > Ground
> > > Control macro software
> > > (http://groups.yahoo.com/group/vantage/files/_Misc/gc.zip), which
> > > basically replays keystrokes in Windows to do the task. It worked
> > fine,
> > > but was unreliable 10% of the time because of flukes in our system
> > (ie.
> > > Vantage taking extra time to logon, or whatever).
> > > Just recently, with the help of a number of folks on the list
> > here, we
> > > came up with something faster and much more reliable using the
> > Progress
> > > programming language. You can use this method even if you don't
> have
> > the
> > > 4GL compiler or the Vantage source code. I can run the very short
> > program
> > > through my Task Scheduler on my PC or it runs from an icon
> (outside of
> > > Vantage) and thus doesn't use a Vantage license. The program is
> easy
> > to
> > > create using the Export utility in Vantage to build the joins I
> want,
> > then
> > > I cut and paste into the program.
> > > If you're interested, I can send you some samples to look at.
> > > Troy Funte
> > > Liberty Electronics
> > > From: lptingley
> > > Sent: Monday, December 10, 2001 8:30 AM
> > > Subject: [Vantage] Automating Exports
> > > Is it possible to automate the exporting of data out of Vantage?
> > > Thanks - Les
> > > Yahoo! Groups Sponsor
> > > ADVERTISEMENT
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
> You
> > must
> > > have already linked your email address to a yahoo id to enable
> access.
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder
> > > and Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/links
> > > Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must
> access.
> Builder
> > and
> > http://docs.yahoo.com/info/terms/
> must
> > have already linked your email address to a yahoo id to enable access.
> Builder
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> ADVERTISEMENT
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Thanks - Les
Les,
We had been exporting data nightly in Vantage for months using Ground Control macro software (http://groups.yahoo.com/group/vantage/files/_Misc/gc.zip), which basically replays keystrokes in Windows to do the task. It worked fine, but was unreliable 10% of the time because of flukes in our system (ie. Vantage taking extra time to logon, or whatever).
Just recently, with the help of a number of folks on the list here, we came up with something faster and much more reliable using the Progress programming language. You can use this method even if you don't have the 4GL compiler or the Vantage source code. I can run the very short program through my Task Scheduler on my PC or it runs from an icon (outside of Vantage) and thus doesn't use a Vantage license. The program is easy to create using the Export utility in Vantage to build the joins I want, then I cut and paste into the program.
Troy Funte
Liberty Electronics
Thanks - Les
ADVERTISEMENT
Hi Troy,
Les Tingley
MIS Director
Decorated Products
> Les,
> Troy Funte
> Liberty Electronics
> From: lptingley
> Thanks - Les
> ADVERTISEMENT
Les,
Below is the text of the Program. Change the company name to your company.(If you cut and paste from Vantage Export Utility, you will need to put your company name here as well. The export uses a variable "cur-comp".) Save the text in a file with a .p extension. Put the file in your Vantage folder (or Vantage/ud). Then create a shortcut on your desktop with the following command line:
N:\progress\bin\prowin32.exe -db n:\vantage\db\vantage.db -N TCP -S servicename -H servername -p n:\vantage\export.p
If you want to use the Procedure Editor to edit and work with your program, you will need to find a way to connect to the database so that you can run it. I usually click Edit/Insert Field, which then prompts me to connect to the database. After connecting, I click cancel and then click F2 t run the program to test it. The Help in Procedure Editor can give you all the fancy stuff like variables, messages, calling other programs, etc.
Troy Funte
Liberty Electronics
export delimiter "," "JobNum" "MtlSeq" "Partum" "Description" "RequiredQty" "IssuedQty" "PartNum" "PartDescription".
for each JobMtl Where JobMtl.Company = 'companyname'
By JobMtl.JobNum:
JobMtl.JobNum
JobMtl.MtlSeq
JobMtl.PartNum
JobMtl.Description
JobMtl.RequiredQty
JobMtl.IssuedQty
JobHead.PartNum
end.
output close.
/* end of export */
Hi Troy,
Les Tingley
MIS Director
Decorated Products
> Les,
> Troy Funte
> Liberty Electronics
> From: lptingley
> Thanks - Les
> ADVERTISEMENT
Troy,
Thanks for the code.
Not sure if you could use this, but from my computer I connect (relatively)
quickly to my test database using the following line in a shortcut :
V:\Progress\bin\prowin32.exe -p _admin.p vantage -N TCP -H
servername -S servicename
That opens a Login dialog box, click Cancel, and you're connected via Data
Administration. Choose Tools, Procedure editor.
Hope it helps
Richard Lafortune
Wulftec International
-----Message d'origine-----
De : Troy Funte [mailto:tfunte@...]
Envoye : Monday, December 10, 2001 9:43 AM
A : vantage@yahoogroups.com
Objet : Re: [Vantage] Automating Exports
Les,
Thanks Troy,
Les
> Les,
> programs, etc.
> Troy Funte
> Liberty Electronics
> By JobMtl.JobNum:
> JobMtl.JobNum
> JobMtl.MtlSeq
> JobMtl.PartNum
> JobMtl.Description
> JobMtl.RequiredQty
> JobMtl.IssuedQty
> JobHead.PartNum
> end.
> output close.
> /* end of export */
> From: Les Tingley
> Hi Troy,
> Thanks,
> Les Tingley
> MIS Director
> Decorated Products
> > Les,
> Ground
> fine,
> (ie.
> here, we
> Progress
> the
> program
> to
> then
> > Troy Funte
> > Liberty Electronics
> > From: lptingley
> > Thanks - Les
> > ADVERTISEMENT
> must
> Builder
> and
When I do multiple exports, I call them one by one from a main export.p program using the "run subexport.p" program. I also added a button to STOP the process, just in case. It helps to add a Target line to your shortcut: n:\vantage, so that you don't have to add the path to each of your run statements.
I use the .csv files by linking them in Access, and then creating a query from them. That way I can use them in Crystal reports or Access reports. Each time the files are exported again, the links are automatically updated with the new data. I've found that adding fields to Vantage Reports this way, rather than through ODBC, eliminates having to have ODBC on those workstations.
I'd love to hear ideas from others on what can be done using these exports.
Troy Funte
Liberty Electronics
Thanks Troy,
Les
> Les,
> programs, etc.
> Troy Funte
> Liberty Electronics
> By JobMtl.JobNum:
> JobMtl.JobNum
> JobMtl.MtlSeq
> JobMtl.PartNum
> JobMtl.Description
> JobMtl.RequiredQty
> JobMtl.IssuedQty
> JobHead.PartNum
> end.
> output close.
> /* end of export */
> From: Les Tingley
> Hi Troy,
> Thanks,
> Les Tingley
> MIS Director
> Decorated Products
> > Les,
> Ground
> fine,
> (ie.
> here, we
> Progress
> the
> program
> to
> then
> > Troy Funte
> > Liberty Electronics
> > From: lptingley
> > Thanks - Les
> > ADVERTISEMENT
> must
> Builder
> and
ADVERTISEMENT
