We have employees forget to clock out at the end of the day. If it’s not caught, the next morning typically is off as well. Is there a way to automatically clock employees out if they aren’t clocked out by 8 pm or some set time? If they are in a job, I’d like it to log them out of the job and clock them out.
I would challenge the reason you clock employees out automatically. If they can’t clock out properly, then time and quantity entries mean nothing… unless corrected. If you can’t rely on accurate clocking, then have labor backflush at standard and make all operations quantity only.
This, of course, is suggested only when you aren’t using Epicor payroll. Although, if you’re using Epicor payroll you wouldn’t be clocking people out automatically since you might be paying them for many extra hours they didn’t work
Jenn
we wrote a routine that we have scheduled to run at one minute past the end of each shift, which will close any labour bookings and clock any employee out in a shift that should of finished.
we had to create more shifts, for example morning overtime, days, evening overtime etc.
It works fine, the only problem being is the task agent does not account for daylight saving time
