you can cut and past the 4GL query from the export module. Combine that
with Troy's examples, you should be ready to go...
Thaddeus
Sent: Tuesday, January 22, 2002 12:04 PM
Subject: [Vantage] automate a stored export routine.
I have been having trouble with ODBC, so I created an export using
the export utility. How can I automate it? Can I create a .p file
or something and then run it with a windows scheduler or something.
I have never worked with vantage or progress and need a little help
getting started. If a .p file can run stored exports please insert
the code. I am also interested in any reading material since the
help files seem to be lacking.
Thank You,
Peter
Thaddeus
Thank You,
Peter
