Hi Paul
Go to System Management>Document Association and specify file types, the
help when you get to the maintenance section is quite good.
Regards Chris Reed
PWSL
Sent: 17 December 2001 12:20
Subject: [Vantage] Re: Autocad
Does anyone know how to set up the document association in Vantage so it
will open ACAD drawings in VoloView?
The other comments regarding the limitations of BOM Import are matching my
personal observations, which if nothing else, indicates that my assumptions
about this module were 99% correct!
Best Regards,
Paul Whittle
Quality Assurance Manager
Jiskoot Autocontrol Ltd.
Tunbridge Wells, Kent TN1 2DJ, UK
Tel +44 (0)1892 518000
Fax +44 (0)1892 518100
www.jiskoot.com
Regards Chris Reed
PWSL
Best Regards,
Paul Whittle
www.jiskoot.com
----- Original Message -----
Sent: Friday, December 14, 2001 7:22 PM
Subject: [Vantage] Digest Number 1629
2001 09:16:24 -0500
> From: Rick Spriggle <rspriggle@...>
> Subject: RE: AutoCAD
> Autocad also has a free viewer called VoloView. It will read and print
any
> dwg format drawing. That would cut out the interim step of creating a pdf
> file and not require a license of Acrobat.
> Rick
> > We use it by converting the AutoCAD image to a .PDF file and use Adobe
> > Reader (free) to view documents via document mgmt.
> > Works very well & minimizes the number of AutoCAD licenses
> > needed ($avings).
> > Rick Joslin
> > V-S Industries
> > rick.joslin@...
