Auto Printing By Date
Thank you. After posting this question and a little more research, I came to the conclusion we would need to run it as a user as well. I even found a post saying someone had contacted Epicor over this and they said it was working as designed. Seems like an odd way to design it. But I guess we can make this work.
--- In vantage@yahoogroups.com, Joshua Giese <jgiese@...> wrote:
> It turned into running an epicor client session as a service on the server and setting up all timed prints as that specific user. I created a user called print for that.
> In your current setup. If the xml is there you should be able to run the report from the system monitor too then as whichever user the report ran as.
> reply Signature
> Joshua Giese
> CTO
> 920.437.6400 Ext. 337
> Site ID: 27450-E905700B2-SQL64
> From: "benthomas82" <benthomas82@...>
> To: vantage@yahoogroups.com
> Sent: Wednesday, February 27, 2013 1:20:38 PM
> Subject: [Vantage] Re: Auto Printing By Date
> Did you ever get this to work? I am in the same situation, the .xml file is generated, but I can't figure out how to actually print the report.
> --- In vantage@yahoogroups.com , "Anon" wrote:
> > I would like to setup monthly reports to run at night and be on the printer in the morning. I can schedule the reports to run at 12am the 1st of every month, with a process set no problem, but how do I get them to show up on a printer.
reply Signature
Joshua Giese
CTO
