Elias
(Elias Serruya)
April 2, 2021, 12:51am
1
I would like to print a report from a customization.
I’m an experienced C# programmer and what I need help with is understanding whether, while using the BOs available for customizations, it is possible to print a Crystal or SSRS report. Specifically, a Bill of Lading report.
From looking the trace log, one of the BOs called during a manual print request (by printing via the menu) is Erp.Proxy.Rpt.BOLFormImpl
and the method called is SubmitToAgent()
<tracePacket>
<businessObject>Erp.Proxy.Rpt.BOLFormImpl</businessObject>
<methodName>SubmitToAgent</methodName>
<appServerUri>net.tcp://ejbdb10/ERP10_2_TEST/</appServerUri>
<returnType>System.Void</returnType>
<localTime>3/31/2021 09:52:43:4439843 AM</localTime>
<threadID>1</threadID>
<executionTime total="426" roundTrip="400" channel="0" bpm="1" other="25" />
<retries>0</retries>
<parameters>
<parameter name="ds" type="Erp.Rpt.BOLFormDataSet">
<BOLFormDataSet xmlns="http://www.epicor.com/Ice/300/Rpt/BOLForm/BOLForm" />
</parameter>
<parameter name="agentID" type="System.String"><![CDATA[SystemTaskAgent]]></parameter>
<parameter name="agentSchedNum" type="System.Int64"><![CDATA[0]]></parameter>
<parameter name="agentTaskNum" type="System.Int32"><![CDATA[0]]></parameter>
<parameter name="maintProgram" type="System.String"><![CDATA[Erp.UIRpt.BOLForm]]></parameter>
</parameters>
<paramDataSetChanges>
<paramDataSet name="ds" useDataSetNbr="0">
[lots of data]
</paramDataSet>
</paramDataSetChanges>
<serverTrace>
<Op Utc="2021-03-31T14:52:43.4067805Z" act="Erp:Rpt:BOLForm/BOLFormSvcContract/SubmitToAgent" dur="381.7919" cli=[myClient] usr=[myUser] machine=[myMachine] pid="14772" tid="105" xmlns="">
<Sql queries="8" cacheHits="0" time="38.2747" qryTypeCount="7" />
</Op>
</serverTrace>
</tracePacket>
I’ve looked into using Erp.Proxy.Rpt.BOLFormImpl
and calling SubmitToAgent()
via the customization with no success.
I’ve searched for a solution for days and didn’t come across a previous case on this, so your input is very appreaciated!
Yoonani
(Yoonhwan Kim)
April 2, 2021, 6:42am
2
I hope this code will help you.
Ice.Core.Session otSession = (Ice.Core.Session)this.oTrans.Session;
String strWorkstationID = Ice.Lib.Report.EpiReportFunctions.GetWorkStationID(otSession);
Erp.Proxy.Rpt.BOLFormImpl report =
WCFServiceSupport.CreateImpl<Erp.Proxy.Rpt.BOLFormImpl>(otSession,
Epicor.ServiceModel.Channels.ImplBase<Erp.Contracts.BOLFormSvcContract>.UriPath);
Erp.Rpt.BOLFormDataSet ds = report.GetNewParameters();
ds.BOLFormParam[0].BOLNum = 1;
ds.BOLFormParam[0].AutoAction = "SSRSPREVIEW";
ds.BOLFormParam[0].AgentSchedNum = 0;
ds.BOLFormParam[0].AgentID = "SystemTaskAgent";
ds.BOLFormParam[0].AgentTaskNum = 0;
ds.BOLFormParam[0].RecurringTask = false;
ds.BOLFormParam[0].RptPageSettings = "";
ds.BOLFormParam[0].RptPrinterSettings = "";
ds.BOLFormParam[0].RptVersion = "";
ds.BOLFormParam[0].ReportStyleNum = 2;
ds.BOLFormParam[0].WorkstationID = strWorkstationID;
ds.BOLFormParam[0].TaskNote = "";
ds.BOLFormParam[0].ArchiveCode = 0;
ds.BOLFormParam[0].DateFormat = "mm/dd/yyyy";
ds.BOLFormParam[0].NumericFormat = ",.";
ds.BOLFormParam[0].AgentCompareString = "";
ds.BOLFormParam[0].ProcessID = "";
ds.BOLFormParam[0].ProcessTaskNum = 0;
ds.BOLFormParam[0].DecimalsPrice = 0;
ds.BOLFormParam[0].GlbDecimalsGeneral = 0;
ds.BOLFormParam[0].GlbDecimalsCost = 0;
ds.BOLFormParam[0].GlbDecimalsPrice = 0;
ds.BOLFormParam[0].SSRSRenderFormat = "PDF";
report.RunDirect(ds);
Yoonani
(Yoonhwan Kim)
April 2, 2021, 6:46am
3
LBARKER
(Lawson Barker)
April 2, 2021, 8:16am
4
This code works also, you can leave the Email part out
Final working code for generating a pdf with your own filename… and emailing it with Outlook
// You will need the following Custom Assembly References
// Erp.Contracts.Rpt.SalesOrderAck
// Erp.UIRpt.SalesOrderAck
// Ice.Contracts.BO.ReportMonitor
// Microsoft.Office.Inerop.Outlook <<<<this can be tricky to locate, when you find it, deploy it you epicor client folder, I found it here:- C:\Windows\assembly\GAC_MSIL\Microsoft.Office.Interop.Outlook
// Microsft.ReportViewer.Common
// Microsft.R…
You may want to give this a read too. Nathan Anderson of Epicor explains:
Let’s talk about SSP (server-side printing) - Experts’ Corner
Elias
(Elias Serruya)
April 5, 2021, 11:11pm
6
Thank you all for the direction. I’ll give it a try tonight and will report back on my progress.
Elias
(Elias Serruya)
April 27, 2021, 12:41am
7
This worked great. I just had to manually import Ice.Core.Session.dll
(to get the workstation ID) and Erp.Contracts.Rpt.BOLForm.dll
(to get the report parameters) via Assembly Reference Manager inside the customization and it worked.
Thank you!
