There's a field on the Report Data Definitions and in Report Styles, that is
the type of report. I believe a couple options are "Base" and "Crystal".
Regardless, if these don't match, I know it causes problems similar to what
you're seeing.
Kevin Simon
Herby Dallard
Sent: Thursday, October 06, 2011 3:11 PM
Subject: [Vantage] Auto Print
I would like to set up a report (Material Tags) to auto-print. I created a
duplicate of the original data definition for a material tags report and
setup the printer and auto print rules, new report style, auto print
condition (using checkbox01 = true). Lastly I created a BAM rule using
LabortDtl table (having checkbox01 -report trigger and other needed fields).
However in the BAM's Action Tab, the report ID and report definition ID does
not appear (only generic job and Genjob); however it does allow me to create
the rules for the LaborDtl table which was added in the Data Definition
which has a relationship created between it and the MTlTags table.
Can anyone help, or does anyone have a successful example I can implement to
see what I am doing incorrectly?
Thanks in advance.
Best Regards,
Herby Dallard
Information Technology Engineer
Endicott Research Group
hdallard@... <mailto:hdallard%40ergpower.com>
607-754-9187 ext. 3078
www.ergpower.com <http://www.ergpower.com/>
you're seeing.
Kevin Simon
Herby Dallard
Thanks in advance.
Best Regards,
Herby Dallard
