Auto log off Vantage users in 6.1
This is standard feature in Vantage 5.2, not sure about 6.x, but would
assume they have it for 6 as well. You can get instructions from Vantage
support on how to implement it. Below are the instructions they had
sent me for 5.2...
Instructions for configuring progress client time-out
Goto your progress/bin directory. In there you have two files we'll be
working with. One is the "ini2reg.exe" (we'll use this program to put
the
client time out function into your registry.) The other file we'll be
using
is the progress.ini. For my example we'll be setting our time out 20
minutes. You can change this number to whatever you want. It does not
time
out data collection/shop floor logins unless they are "crashed out".
1. First thing you want to do is make a backup of your progress.ini.
MAKE
SURE YOU DO THIS!!!
2. Edit your progress.ini file(make sure you have a backup) erase
everything out of it and put the following
[Startup]
ClientTimeOut=20
3. Save this as progress.ini
4. Double click on the file "ini2reg.exe" an interface will come up.
In
the "1)Enter the name of the .INI file you wish to translate." field
browse
out to your modified version of the progress.ini(the one with just
"[Startup] ClientTimeOut=20" in it) In the "2)Select the Registry base
key"
select HKEY_CURRENT_USER then click on "Translate". Next in the
"2)Select
the Registry base key" select HKEY_LOCAL_MACHINE and click on
"Translate".
(**NOTE**In a previous version of Progress I had to translate it into
HKEY_USERS. You may have to do this if yours doesn't work.) OK we're
done
here let's exit out.
5. Erase your modified version of the progress.ini.
6. Put back your original version of the progress.ini.
7. Now let's edit your original version of the progress.ini and make
one
change.
8. In your progress.ini your going to put the ClientTimeOut value.
Don't
erase anything out of the progress.ini. We're just going to add a line
to
it now. Make sure it's for the same number of minutes you had in your
modified version. It should look something like this. Look 5 lines
down.
[Startup]
V6Display=no
;ImmediateDisplay=yes
;MultitaskingInterval=100
ClientTimeOut=20
DefaultFont=MS Sans Serif, size=8
DefaultFixedFont=Courier New, size=8
DLC=d:\epic52\progress
Use-3D-Size=Yes
PROBUILD=d:\epic52\progress\PROBUILD
PROPATH=.,d:\epic52\progress\gui,d:\epic52\progress,d:\epic52\progress\b
in,d
:\epic52\progress\PROBUILD\EUCAPP\EUC.PL,d:\epic52\progress\PROBUILD\EUC
APP
[Colors]
9. Now save the progress.ini and exit. Reboot your server.
10. From now on any clients that are idle for more than 20 minutes will
get
logged out of Vantage or any crashed processes after 20 minutes will be
cleaned up thus giving you back your Vantage license.
This is a built in feature in Progress and they do support it.
<DIV><font size="1.5" face="Bookman Old Style">__________________________________________________________________________________________________________________
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
__________________________________________________________________________________________________________________<DIV><FONT>
I know I have seen on this usergroup a post that someone developed a rutine to log people off of Vantage after a certain time frame for Vantage 6.1.  I was wondering if someone still has it and could email me the routine or the file to accomplish this task.  We do not however want to log our plant floor stations off.
Thank you,
Jeff Keizer
IT Manager
Yahoo! Canada Toolbar: Search from anywhere on the web, and bookmark your favourite sites. Download it now at
http://ca.toolbar.yahoo.com
This is a built in feature in 6.1 with Progress 9.1d. The main limitation is that it applies to everyone so you can't exclude specific people or set different time limits. On the rother hand because data collection screens update the time they produce constant activity and thus do not get logged off....a trick some people may figure out to run Office Data Collection minimized and prevent time-out.
If is a simple registry setting...I can't recall at the moment but is detailed in the Vantage knowledgebase.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jeff Keizer
Sent: Monday, June 02, 2008 9:23 AM
Subject: [Vantage] Auto log off Vantage users in 6.1
Thank you,
Jeff Keizer
IT Manager
Thank you for the reply but I have logged on to the Vantage Knowledge base and could not find any references to this.  If you can find it and email me the document that would be greatly appricatied.
Jeff K
--- On Mon, 6/2/08, Todd Caughey <caugheyt@...> wrote:
Subject: RE: [Vantage] Auto log off Vantage users in 6.1
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Received: Monday, June 2, 2008, 10:32 AM
-Todd C.
____________ _________ _________ __
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Jeff Keizer
To: vantage@yahoogroups .com
I know&nbsp;I have seen on this usergroup a post that someone developed a rutine to log people off of Vantage after a certain time frame for Vantage 6.1.&nbsp; I was wondering if someone still has it and could email me the routine or the file to accomplish this task.&nbsp; We do not however want to log our plant floor stations off.
&nbsp;
Thank you,
&nbsp;
Jeff Keizer
IT Manager
____________ _________ _________ _________ _________ _________ _
http://ca.toolbar yahoo.com.
Ask a question on any topic and get answers from real people. Go to Yahoo! Answers and share what you know at http://ca.answers.yahoo.com
I'm new to Vantage and looking for that same feature. Can you email
me the details or point me in the right direction?
Thanks!
John
off.
> Thank you,
> Jeff Keizer
> IT Manager
Jeff and John,
Here is a copy of an earlier post on the timeout utility, I use this and
it works fine. It is not supposed to log out shop floor data collections.
ClientTimeOut=n
where n is the number of minutes a client can be idle before the server
disconnects it.
This ClientTimeOut parameter must be put into the registry of the server
machine, in one of the following keys, by default this key will not exist so
will need to be created.
HKEY_CURRENT_USER\SOFTWARE\PSC\PROGRESS\<VERSION>\STARTUP
or
HKEY_LOCAL_MACHINE\SOFTWARE\PSC\PROGRESS\<VERSION>\STARTUP
where <version> is the current version (e.g. 9.1D).
Dennis
> Thanks!
> John
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>,
> off.
> > Thank you,
> > Jeff Keizer
> > IT Manager
> > http://ca.toolbar.yahoo.com <http://ca.toolbar.yahoo.com>
