Can Epicor automatically generate transfer order requirements when the number of a part hit the min? Thanks,
Hi Ben,
If you use MRP it makes transfer order suggestions that may be firmed. The suggestion can come from going below SS in a “transfer” site. This entails the part setup on the part/site tab for the site to be transferred to as source type transfer and then the supply part site needs to be setup for purchase or manufacture as needed.
Nancy
Hi Nancy,
Thank you very much for your info.
