Wonder if Epicor has any audit trail report that can identify the users who made changes such as creating a new job entry, adding, deleting or editing a supplier list, etc.
This is one of the question that auditor will frequently ask about traceability and accountability.
Epicor does indeed have changelogs, however, if the record is deleted, there is no log. If you want to track deletions, you will need to write a BPM to record the data in a UD table for displaying in a dashboard
At some point in the past, Epicor had published KB article KB0052886, Enabling Change Log on a Table Missing the Option, but it seems that article is no longer accessible via EpicCare. However, you can still reference that article here on the forum:
I am able to follow the steps to detect that a Job has been unreleased and send email notification using Method Directives, Business Object: Job Entry and Method Code: Erp.JobEntry.ChangeJobHeadJobReleased
The challenge is there are so many fields in the Business object and how one is able to know which field to use. For this case is ChangeJobHeadJobRelease.
Example, I try to monitor who has delete or amended the Vendor.
Not difficult to guess the Business Object is Vendor. But it’s difficult to know which field in Vendor table to use.
Any simple ways that we can identify which field to use in the table rather than guessing and trying different fields?
