I attached a PDF to a Part and was expecting it to also be attached when I create a job for that part. I believe this worked way back in V6. I don’t even see the paperclip icon in job entry. Am I missing a feature?
Maybe dumb question, but is the same part rev?
Epicor said to attach it in the engineering workbench and that worked - became attachment to the job.
Randy,
I may be late to the table here, but if you link the attachment to the part revision it will attach to a job with the details from that revision.
For every new revision it will then need to be re-attached again.
Brad
Yes - got it now. Thanks.
