Assign Task Message Content
We are implementing 905.605
Is there a way to customize or add data tags to the Alert that is sent when a task is assigned or completed, so it is more meaningful?
Thanks for any advice you can give.
Greg Payne
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at (727) 578-6258 and immediately delete the communication.
