Thanks, I forgot about that limitation.
The ARForm.rpt is full of subreports, so obviously my suggestion won't work.
It really depends on what kind of variations you're looking for, but it sounds like your approach is the only way to go for the ARForm.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Sean McDaniel
Sent: Tuesday, May 04, 2010 12:46 PM
Subject: RE: [Vantage] AR Invoice Form - Different Form depending on Customer - Vantage - 8.03.405
Subreports might not be the best way to go on this. You are limited to only a single level of subreport, so this is usually the first problem in going this direction.
What you can do is right-click on a section and “add section belowâ€, Copy from the above section and make any changes. Then on the section detail, create a suppression formula allowing only one section to be visible at a time.
Easy to do and no linking of subreports.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Brychan Williams
Sent: Tuesday, May 04, 2010 12:17 PM
Subject: Re: [Vantage] AR Invoice Form - Different Form depending on Customer - Vantage - 8.03.405
Hi,
Thanks , thats what I thought.... Would be a nice feature....
From: Brian W. Spolarich <bspolarich@... <mailto:bspolarich%40advancedphotonix.com> >
Sent: Tue, 4 May, 2010 14:23:26
I don't think you'll be able to do this in Vantage, at least not easily, so you'll need to do it in Crystal.
Here's one thought though: use subreports.
Basically suppress all of the sections of a blank report except for the report header.
Insert as many additional report header sections as you need for the number of different report variations you're going to have.
Insert one subreport in each of the report header sections. If you already have the report files for the intended variations, you can select them when you create the subreport. Otherwise import the base form and modify each subreport variation as you need to.
Link each subreport's data to the main reports data bringing in all tables.
Conditionally suppress each section based on the customer ID so that only one shows at a time.
That should do what you want.
-bws
bspolarich@advanced photonix. com ~ 734-864-5618 ~ www.advancedphotoni x.com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of brychanwilliams
Sent: Tuesday, May 04, 2010 7:33 AM
To: vantage@yahoogroups .com
Subject: [Vantage] AR Invoice Form - Different Form depending on Customer - Vantage - 8.03.405
Hi,
I was wondering wether there is way to automate a different ar invoice form depending on the customer. I know that you could have one crystal report and do some tricks to create different outputs but is there way to call a completely different crystal report automatically , rather than the user selecting a different report style .
Thanks in advance.
Hi
-bws
Hi,
-bws
Hi,
Thanks in advance.
Hi
