So our AR Aging report right out of the box, there’s the Contact Person and Phone is not populating. Trying to figure out where this is coming from. When I open the RDD, I see ARDtls, but this doesn’t seem to be a table. There’s about 54 calculated fields. Any ideas where this is coming from? Also what’s strange is that if we export the report into csv the “PO(s)” does not come through. It’s there in the SSRS report, but not showing when exporting to csv. Any ideas?
I would start with Customer Maintenance > Contacts tab. Then, select a contact and make it the primary contact for billing and see what happens. If you already have this, then we will need to check it out further.
Thank you. That worked.
