Ran the APR today and received the error message below. We had most of our invoices go through, but this one got stuck and not sure why. I see it says invalid column PackNum_Name, but not sure why as this has not come up before. Also, how do we know which one was not pushed through?
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: System.Web.Services.Protocols.SoapException: An error has occurred during report processing. —> Microsoft.ReportingServices.ReportProcessing.ProcessingAbortedException: An error has occurred during report processing. —> Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for dataset ‘ARForm’. —> System.Data.SqlClient.SqlException: Invalid column name ‘PackNum_Name’.
at Microsoft.ReportingServices.Library.ReportExecution2005Impl.InternalRender(String Format, String DeviceInfo, PageCountMode pageCountMode, Stream& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at Microsoft.ReportingServices.Library.ReportExecution2005Impl.Render(String Format, String DeviceInfo, PageCountMode pageCountMode, Byte[]& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
at Microsoft.ReportingServices.WebServer.ReportExecutionService.Render(String Format, String DeviceInfo, Byte[]& Result, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds)
Stack Trace:
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Ice.Core.SsrsReportService.ReportExecutionService.Render(String Format, String DeviceInfo, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds) in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\Web References\SsrsReportService\Reference.cs:line 633
at Ice.Core.SsrsReporting.SsrsRendererBase.Render(SsrsRenderInformationBase renderInformation) in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 142
at Ice.Core.SsrsReporting.SsrsRendererBase.<>c__DisplayClass12_0.b__0() in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 87
at Epicor.Hosting.Trace.TraceHandle.TimeAction(Action actionToTime) in C:_Releases\ICE\ICE3.2.300.10\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 92
at Epicor.Hosting.Trace.TraceHandle.AddTimedIfEnabled(String traceFlag, Action actionToTime, Func2 messageBuilder) in C:\_Releases\ICE\ICE3.2.300.10\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 39 at Ice.Core.SsrsReporting.SsrsRendererBase.TraceReportRendered(String printProgram, String ssrsRenderFormat, Func
1 timedAction) in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 95
at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReportForPreviewOrGenerate(RenderedSsrsReport renderedReport) in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 264
at Ice.Core.SsrsReporting.ReportProcessorBase.ProcessReportPart(String reportLocation) in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 158
at Ice.Core.SsrsReporting.ARFormReportProcessor.ProcessReportParts() in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ARFormReportProcessor.cs:line 42
at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(ReportInstanceInformation reportInstance, Func2 reportsRenderer, Action
1 fillSysRptLstRow, Action2 processReport, Func
3 filterTableAttachmentsFunc) in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 57
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RenderUnroutedSsrsReport() in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 303
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RunSsrsReportIfEnabled() in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 228
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.ProcessReportWithDataInPlace(Func2 executeCommand, Func
2 executeReader, SqlObjectsCreated sqlObjectsCreated) in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 111
at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 93
at Ice.Core.RptTaskBase1.XMLClose() in C:\_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 216 at Erp.Internal.AR.ARInvForm.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_Releases\ERP\UD10.2.300.10\Source\Server\Internal\AR\ARInvForm\ARInvForm.cs:line 1272 at Ice.Core.TaskBase
1.StartProcess(Int64 instanceTaskNum, String outputFileName) in C:_Releases\ICE\ICE3.2.300.10\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 47
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:_Releases\ICE\ICE3.2.300.10\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 98
at Ice.Hosting.TaskCaller.ExecuteTask() in C:_Releases\ICE\ICE3.2.300.10\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 57
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in c:_Releases\ICE\RL3.2.300.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in c:_Releases\ICE\RL3.2.300.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 577
