While creating Apply Credit Memo through BPM Custom code, error is coming. The same error is coming in BL Tester. Anyone has solution to fix the issue, please suggest.
GetHdrDocumentInfo Method call throws error.
Erp.Contracts.ApplyCreditMemoSvcContract ApplyCMHed = null;
ApplyCMHed = Ice.Assemblies.ServiceRenderer.GetService<Erp.Contracts.ApplyCreditMemoSvcContract>(Db);
var ApplyCMHedds = new Erp.Tablesets.ApplyCreditMemoTableset();
ApplyCMHed.GetNewCashHead(ref ApplyCMHedds, strgroupID);
ApplyCMHed.OnDocumentTypeChanging(ref ApplyCMHedds, “CM”);
ApplyCMHed.GetHdrDocumentInfo(10100, ref ApplyCMHedds);
Server Side Exception
BPM runtime caught an unexpected exception of ‘DivideByZeroException’ type.
See more info in the Inner Exception section of Exception Details.
Error Detail
Description: BPM runtime caught an unexpected exception of ‘DivideByZeroException’ type.
Program: CommonLanguageRuntimeLibrary
Method: FCallDivide
Original Exception Type: DivideByZeroException
Framework Method: calcCashHeadBalance
Framework Line Number: 433
Framework Column Number: 13
Framework Source: calcCashHeadBalance at offset 197 in file:line:column C:_projects\ERP\RL10.2.300.0\Source\Server\Services\BO\ApplyCreditMemo\ApplyCreditMemo.cs:433:13
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Erp.Proxy.BO.ARInvoiceImpl.OnChangeBlockedFin(Int32 invoiceNum, ARInvoiceDataSet ds)
at Erp.Adapters.ARInvoiceAdapter.OnChangeBlockedFin(Int32 invoiceNum)
Inner Exception
Attempted to divide by zero.
