So you would have to have a different department number for various
sections of your balance sheet? This would not work for us, as we are
currently setup since all of our balance sheet accounts are in the same
department.
We do not have the P/R module, so I can't help you there, but I would
assume so. We use MES to capture direct labor to the work order.
Engineering charges most of their time to development jobs, but this in
entered manually. I have to do 1 entry a month to reclass the
engineering O/H to the correct G/L account. We have a very simple setup
with one O/H rate for production & 1 for engineering.
Hope this helps.
Tim
Of Gary Parfrey
Sent: Wednesday, October 29, 2008 6:44 AM
Subject: RE: [Vantage] Applied Labor & Overhead
Michelle
No, it a matter of having a department associated with the relevant
labor entry. Whichever shop employee logs the labor recovery is the one
that assigns the department criteria. In Europe the payroll module is
not sold as a module, so users setup shop employees under job management
and still collect GL entries divisionally/departmentally. The same would
apply to any user with the payroll.
Regards
Gary
Behalf
Of Michelle C. Grman
Sent: 29 October 2008 13:07
We do have the payroll module, but we currently do not use it. Is one
of the criteria for this to work is to have all of the employees set up
in the payroll module?
Behalf
Of Tim Macy
Sent: Tuesday, October 28, 2008 5:55 PM
Only if you have the payroll module.
Behalf
Sent: Tuesday, October 28, 2008 1:50 PM
Subject: [Vantage] Applied Labor & Overhead
Is there any way to direct the applied labor and applied overhead to
multiple general ledger accounts in 8.03.404A? I only find one place,
which is in Company Maintenance, where you assign an account for applied
labor and an account for applied overhead. Is there somewhere in setup
that applied labor can be directed to different general ledger accounts
based upon departments?
Michelle C. Grman
Assistant Controller
KERUSSO
The Greek word means - To herald divine truth as a public crier; to
preach the gospel.
P.O. Box 32
Berryville, AR 72616
Phone: 870-423-6242 Ext. 267
Fax: 870-423-3568
Web Site: www.kerusso.com
Shannon Mitchell of Holy Grounds Store says,
'Kerusso products ARE SELLING when others are not.'
You, too can EXPERIENCE SALES SUCCESS with Kerusso when other products
are just taking up space.
Talk with your account rep today!
CONFIDENTIALITY STATEMENT:
This message, from Kerusso Inc., contains information
which is privileged and confidential and is solely for the use of
the intended recipient. If you are not the intended recipient, be
aware that any review, disclosure, copying, distribution, or use
of the contents of this message is strictly prohibited. If you have
received this in error, please destroy it and notify us immediately
at: 800-424-0943
department.
Hope this helps.
Tim
Of Gary Parfrey
Michelle
Regards
Gary
Behalf
Behalf
Of Tim Macy
Behalf
Michelle C. Grman
KERUSSO
preach the gospel.
P.O. Box 32
Fax: 870-423-3568
at: 800-424-0943
