Application Studio
I’m new to editing forms in Application Studio. I want to add a section for a UD field on the details page.
Under print status:
It won’t let me add a column under print status. What am i missing? Can you not add a new section in certain places on these screens?
Are you on the right layer? i.e. header vs. detail. Even if the controls show up when you open the layer its not always the layer that actually contains those controls, if that makes any sense. I wish you could click on a control and see the parent layer under properties in application studio, that would eliminate a lot of guess work.
Thanks! I’ll check and see if I can drill down. Applicaiton Studio seems cool but also very confusing in all of the layers in the flow.
Youre Not Wrong Season 3 GIF by Paramount+
To Alisa’s point, it looks like you’re in Job Entry.
You can add a control to that group when under the Details tab, but not the Main tab, which is what I suspect you’re in.
Bingo! Thank you all for you help. I was in the wrong tab in the layers.
