Been following this masterpiece by @hmwillett and we have run into a small issue when trying to pass a value:
We have a button built that calls the DMR Entry screen. We have a grid that shows all DMR’s. I want to select a value in the grid and pass its DMR number to the DMR Entry screen. When trying the context shown in the example:
{"options": {
"valueIn": "{CAST(NonConf_DMRNum AS Integer)}"
we get the following error:
@hmwillett You said in step one that you had bound a text box to a value. Would you mind helping me do the same but for this grid view?
So, I just ran through this example again and it worked the same way with a grid, so long as the grid is bound to a DataView.
Looking at example, a couple things come to mind.
Why are you casting it? It should already be an integer, no?
You need to reference your DataView, so it should be something like this:
Thanks a ton for getting back! I’ll give those changes a stab. We were attempting a cast because of the error we were receiving “Alpha compare against Numeric Column”. We thought we might be passing a non-numeric value in by accident so we were trying to force it over to a numeric.
