I don’t have a solution for you, just wanted to point out that I’ve found the same behavior when exporting Kinetic Application layers from one environment (test) to another (prod) in 2023.1. Any hidden columns are fully removed from the dataview, which caused me an issue with uBAQs and Key Fields
