Application Studio - Process Calling
Hi,
I’m trying to convert a customization we have on the ‘Select Serial Number’ page.
In Classic we created a menu option calling the ‘Select Serial Number’ dll, with the customization defined against it. We then created a record in ‘Process Calling’ to call the customized menu from screens like ‘Quantity Adjustment’ where you need to specify serial numbers.
This works as expected.
I have updated the menu entry to reference the kinetic menu item, with the published layer specified.
The URL for the menu item is
https://aaaaa.com/aa/Apps/ERP/Home/#/view/preview/Erp.UI.SelectSerialNumbersEntry?channelid=111111&preview=true&useBroadcast=1&**layerNames=1_0_Working**&company=aaaa&site=aaaa&autoload=false
However, when I run this in application the URL that is called is
https://aaaaa.com/aa/Apps/ERP/Home/#/view/preview/Erp.UI.SelectSerialNumbersEntry?channelid=111111c&preview=true&useBroadcast=1&company=aaaa&site=aaaa&autoload=false
The ‘layerNames’ argument is missing.
Is there a new process in Kinetic that replaces ‘Process Calling’?
Andrew.
A bit more digging and I can see the call to the Serial number URL is in a locked event.
