Please let me know how to configure or install the field help and application help
Error Detail
Message: The help system is not configured correctly. This can happen when the .sysconfig file you used to launch the application is not configured correctly or the help URL is not specified in Company Maintenance.
Program:
Method:
The URL for the hosted help by Epicor is like this: https://help.epicor.com/102300. Just change the ending to your version.
If you install the extension it’s whatever you set the URL to in the extension config. If you need help installing the extension take a look at the new install guide on EpicWeb. They cover installing extensions.
