Appending MFG Details to multiple lines
Is there an option to append manufacturing details to multiple lines when building quotes in Quote Entry?
No, but you can pull in the MOM from one of the lines into the others by clicking on the engineering area.
You will have to make the line a template to pull it in.
Hi Bruce,
Does that work for line by line, or does it apply to all applicable lines? If possible, I’m trying to minimize applying the MOM to each individual line if I can apply to a group of lines at once.
Kyle Peace | Account Manager
KENCOA AEROSPACE
OFFICE: 1-478-374-7766 EXT.: 232 | DIRECT: 478-298-4899 | FAX: 1-478-374-9030
USA: 345 Airport Road, Eastman GA 31023 USA (SBA HUBZONE)
KOREA: Sacheon, South Korea
EXPORT SENSITIVE: ITAR CONTROLLED
This document may contain Technical Data whose export is restricted by the Arms Export Control Act (Title 22, U.S.C., Sec 2751, et seq.). Violations of these export laws are subject to severe criminal penalties. This data may not be resold, diverted, transferred, transshipped, made available to a foreign national within the United States, or otherwise disposed of in any other country outside of its intended destination, either in original form or after being incorporated through an intermediate process into other data without the prior written approval of the US Department of State.
<img width=“96” height=“48” style=“width:1.0in;height:.5in” id=“Picture_x0020_2” src="/uploads/default/original/3X/d/f/df7f24ce55ea7de1db124004862db01d0f9524bd.jpeg" alt="A picture containing text, clipart
Description automatically generated">
It would be line by line, but you could assign a HotKey to semi-automate the process.
Ah – I’ll try that out, thanks Bruce!
KENCOA AEROSPACE
