App Studio - Changes to BAQ
If I add another display field to a BAQ that is currently in a custom layer panel card, how do I add that new display field column? Do I need to delete the panel card BAQ and the add it again? What about updating a calculated field? It doesn’t seem like these changes to the BAQ itself will update in App Studio. Must be doing something wrong.
Add it to the columns section in the Grid Model.
The big downside is that they haven’t allowed us to re-order the columns (yet?).
So… if you added a column to your BAQ that you want to show up earlier in your grid… you have to delete columns from the Grid Model and then re-add them in the order you want them to appear.
You can use the personalization of the grid within App Studio to reorder the columns.
It works 60% of the time, every time.
I can probably make a little temp tool to fix that. Remind me later.
Thank you! Forgot this step.
