Here I go again with another (more than likely) silly problem.
I am working with Function maintenance for the first time, and have prepared a function to be tested. The library has been promoted to production, the function has been tied to an OnClick() event, and the necessary parameters have been set.
I generated an API key with no specific Access scope, and an expire date of many years out. This key was then plugged in to the function attached to the OnClick().
When I activate the OnClick() event, and debug in the F12 menu, I get this:
I tried testing the function within the REST API Help page, using the same API key as the header, with the same result.
Any ideas? I’m guessing there is something simple I’ve missed while learning this process.
Thanks in advance
Our company is in the process of moving from 10.700 to Kinetic, so I’ve been working on customization uplift. With that, I haven’t even logged in to the live environment yet.
I tried a couple different times making a key in the Pilot client, and the Pilot web version, both with no success.
It makes a key that doesn’t work. Epicor gives no information in the error, just a “Something went wrong, please contact your system administrator.”
