adlaws1
(Andrew Laws)
December 18, 2020, 4:20pm
1
Hi
I am using the demo code to attempt to connect to the web services
ServicePointManager.ServerCertificateValidationCallback += (sender, certificate, chain, errors) => { return true; };
EndpointBindingType bindingType = EndpointBindingType.SOAPHttp;
string epicorUserID = “********”; << my epicor login
string epiorUserPassword = “****”; << my password
string scheme = "http";
if (bindingType == EndpointBindingType.BasicHttp)
scheme = "https";
UriBuilder builder = new UriBuilder(scheme, "e10server3.internal.labs.com");
// http:///EpicorERPTest/Ice/Lib/SessionMod.svc
// change 'ERP100500' to the name of your appserver
builder.Path = "EpicorERPTest/Ice/Lib/SessionMod.svc";
SessionModSvcContractClient sessionModClient = GetClient<SessionModSvcContractClient, SessionModSvcContract>(
builder.Uri.ToString(),
epicorUserID,
epiorUserPassword,
bindingType);
builder.Path = "EpicorERPTest/Erp/BO/AbcCode.svc";
ABCCodeSvcContractClient abcCodeClient = GetClient<ABCCodeSvcContractClient, ABCCodeSvcContract>(
epicorUserID,
epiorUserPassword,
bindingType);
Guid sessionId = Guid.Empty;
sessionId = sessionModClient.Login();
All works until i call the login method and i get the following error
System.ServiceModel.EndpointNotFoundException: ‘There was no endpoint listening at http://e10server3.internal.labs.com/EpicorERPTest/Ice/Lib/SessionMod.svc that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more details.’
if i have checked the url and all seems to be ok
Any pointers please this is driving me insane
Olga
(Olga Klimova)
December 18, 2020, 4:26pm
2
Do you have
<add scheme="http" binding="wsHttpBinding" bindingConfiguration="SOAPHttp" />
in your web.config protocolMapping?
adlaws1
(Andrew Laws)
December 21, 2020, 8:57am
3
Hi
No this has not help still getting the same error any help would be very much appreciated
Regards
Andy
EndpointNotFoundException: There was no endpoint listening at http://e10server3.internal.labs.com/EpicorERPTest/Ice/Lib/SessionMod.svc that could accept the message. This is often caused by an incorrect address or SOAP action. See InnerException, if present, for more details.]
System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) +159
System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) +353
adlaws1
(Andrew Laws)
December 21, 2020, 9:22am
4
Hi
Using the SvcUtil.exe tool i get the following
Access to the path ‘C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.8 Tools\SessionModSvcFacade.cs’ is denied.
adaniell
(Adam)
December 22, 2020, 7:38pm
5
Your URI doesn’t look quite right, try:
UriBuilder builder = new UriBuilder(scheme, "e10server3");
Also, you can browse to endpoint or wsdl. You can use this to verify your URL:
adlaws1
(Andrew Laws)
December 23, 2020, 8:18am
6
Hi
Thanks for the response, it seems the server address is good as you can see the, i have tried everything so any help would be appreciated
adlaws1
(Andrew Laws)
December 23, 2020, 9:04am
7
This is the section of my web config
<system.serviceModel>
<protocolMapping>
<remove scheme="net.tcp" />
<!--<add scheme="net.tcp" binding="customBinding" bindingConfiguration="TcpCompressedWindows" />-->
<!--<add scheme="net.tcp" binding="customBinding" bindingConfiguration="TcpCompressedUsernameSslChannel" />-->
<add scheme="net.tcp" binding="customBinding" bindingConfiguration="TcpCompressedUsernameWindowsChannel" />
<remove scheme="http" />
<add scheme="http" binding="customBinding" bindingConfiguration="HttpBinaryUsernameSslChannel" />
<add scheme="http" binding="customBinding" bindingConfiguration="HttpsOffloadBinaryUserNameChannel" />
<add scheme="http" binding="customBinding" bindingConfiguration="HttpsOffloadBinaryAzureChannel" />
<remove scheme="https" />
<add scheme="https" binding="customBinding" bindingConfiguration="HttpsBinaryUsernameChannel"/>
<add scheme="https" binding="customBinding" bindingConfiguration="HttpsBinaryAzureChannel"/>
<add scheme="https" binding="customBinding" bindingConfiguration="HttpsBinaryWindowsChannel"/>
<add scheme="https" binding="basicHttpBinding" bindingConfiguration="BasicHttp" />
</protocolMapping>
<services>
<service name="Epicor.Web.TokenResource">
<endpoint address="" behaviorConfiguration="webBehavior" binding="webHttpBinding" bindingConfiguration="RestHttps" contract="Epicor.Web.TokenResource" />
</service>
<service name="Erp.Services.Web.ECC">
<endpoint address="" behaviorConfiguration="webBehavior" binding="webHttpBinding" bindingConfiguration="RestHttps" contract="Erp.Services.Web.ECC" />
</service>
</services>
<bindings>
<!--REST/OData - Authentication: Epicor Username - Channel encrypted via https -->
<webHttpBinding>
<binding name="RestHttps" transferMode="Buffered">
<security mode="Transport">
<transport clientCredentialType="InheritedFromHost" />
</security>
<readerQuotas maxArrayLength="2147483647" maxBytesPerRead="2147483647" maxDepth="2147483647" maxStringContentLength="2147483647" />
</binding>
</webHttpBinding>
<!--SOAP 1.1 - Authentication: Epicor Username - Channel encrypted via https -->
<basicHttpBinding>
<binding name="BasicHttp" maxReceivedMessageSize="2147483647">
<security mode="TransportWithMessageCredential">
<message clientCredentialType="UserName" />
</security>
</binding>
</basicHttpBinding>
<!--SOAP 1.2 - Authentication: Epicor Username - Message encrypted -->
<wsHttpBinding>
<binding name="SOAPHttp" maxReceivedMessageSize="2147483647">
<security mode="Message">
</security>
</binding>
</wsHttpBinding>
<customBinding>
<!--HTTPS - Authentication: Epicor Username - Channel encrypted via https -->
<binding name="HttpsBinaryUsernameChannel" openTimeout="00:10:00" receiveTimeout="9:00:00" sendTimeout="9:00:00">
<binaryMessageEncoding compressionFormat="Deflate">
<readerQuotas maxDepth="50" maxArrayLength="2147483647" maxBytesPerRead="2147483647" />
</binaryMessageEncoding>
<security authenticationMode="UserNameOverTransport" />
<httpsTransport maxReceivedMessageSize="2147483647" maxBufferSize="2147483647" />
</binding>
<!--HTTPS - Authentication: Windows credentials - Channel encrypted via https -->
<binding name="HttpsBinaryWindowsChannel" openTimeout="00:10:00" receiveTimeout="9:00:00" sendTimeout="9:00:00">
<security authenticationMode="SspiNegotiatedOverTransport" requireSecurityContextCancellation="False" />
</binding>
<!--HTTPS - Authentication: Azure AD token - Channel encrypted via https -->
<binding name="HttpsBinaryAzureChannel" openTimeout="00:10:00" receiveTimeout="9:00:00" sendTimeout="9:00:00">
</binding>
<!--HTTP - Authentication: Epicor Username - Channel not encypted - SOAP SSL message security is used-->
<binding name="HttpBinaryUsernameSslChannel" openTimeout="00:10:00" receiveTimeout="9:00:00" sendTimeout="9:00:00">
<readerQuotas maxDepth="50" maxArrayLength="2147483647" maxBytesPerRead="2147483647" maxStringContentLength="2147483647" />
<security authenticationMode="UserNameForSslNegotiated" requireSecurityContextCancellation="False" />
<httpTransport maxReceivedMessageSize="2147483647" maxBufferSize="2147483647" />
</binding>
<!--HTTP - Authentication: Epicor Username - Channel not encypted - SSL Offloading must be done on proxy-->
<binding name="HttpsOffloadBinaryUserNameChannel" openTimeout="00:10:00" receiveTimeout="9:00:00" sendTimeout="9:00:00">
<security authenticationMode="UserNameOverTransport" allowInsecureTransport="True" />
</binding>
<!--HTTP - Authentication: Azure AD token - Channel not encypted - SSL Offloading must be done on proxy-->
<binding name="HttpsOffloadBinaryAzureChannel" openTimeout="00:10:00" receiveTimeout="9:00:00" sendTimeout="9:00:00">
</binding>
<!--NET.TCP - Authentication: Epicor Username - Channel encrypted via SSL -->
<binding name="TcpCompressedUsernameSslChannel" openTimeout="00:10:00" receiveTimeout="9:00:00" sendTimeout="9:00:00">
<CompressionEncoder>
<binaryMessageEncoding>
</CompressionEncoder>
<sslStreamSecurity />
<tcpTransport maxReceivedMessageSize="2147483647" maxBufferSize="2147483647" transferMode="Buffered" />
</binding>
<!--NET.TCP - Authentication: Windows Credentials - Channel encrypted via Windows Trusted Domain between Client and Server -->
<binding name="TcpCompressedWindows" openTimeout="00:10:00" receiveTimeout="9:00:00" sendTimeout="9:00:00">
<windowsStreamSecurity />
</binding>
<!--NET.TCP - Authentication: Epicor Username - Channel encrypted via Windows Trusted Domain between Client and Server -->
<binding name="TcpCompressedUsernameWindowsChannel" openTimeout="00:10:00" receiveTimeout="9:00:00" sendTimeout="9:00:00">
</binding>
</customBinding>
</bindings>
<extensions>
<bindingElementExtensions>
<add name="CompressionEncoder" type="Epicor.ServiceModel.Configuration.CompressionEncodingElement, Epicor.ServiceModel, Culture=neutral" />
</bindingElementExtensions>
<behaviorExtensions>
<add name="AddressFilterModeAny" type="Epicor.Hosting.Wcf.AddressFilterModeAnyElement, Epicor.System, Culture=neutral" />
</behaviorExtensions>
</extensions>
<behaviors>
<endpointBehaviors>
<behavior name="webBehavior">
<webHttp helpEnabled="true" />
</behavior>
</endpointBehaviors>
<serviceBehaviors>
<behavior>
<serviceThrottling maxConcurrentCalls="15120" maxConcurrentSessions="500000" maxConcurrentInstances="15120" />
<serviceDebug includeExceptionDetailInFaults="true" />
<serviceMetadata httpGetEnabled="true" />
<serviceSecurityAudit auditLogLocation="Application" serviceAuthorizationAuditLevel="Failure" messageAuthenticationAuditLevel="Failure" suppressAuditFailure="true" />
<serviceCredentials>
<!-- Uncomment for Ssl. Set FindType and Value based on your Certificate -->
<userNameAuthentication userNamePasswordValidationMode="Custom" customUserNamePasswordValidatorType="Ice.Security.UsernameValidator, Epicor.Ice, Culture=neutral" />
<clientCertificate>
<authentication revocationMode="NoCheck" certificateValidationMode="PeerOrChainTrust" />
</clientCertificate>
<!--<serviceCertificate x509FindType="FindBySubjectName" findValue="E10SERVER3.internal.labs.com" storeLocation="LocalMachine" storeName="My" />-->
</serviceCredentials>
Note: This service authorization entry must exist to validate calls destined for ICE or Ice-derived application services.
<serviceAuthorization serviceAuthorizationManagerType="Ice.Security.AuthorizationManager, Epicor.Ice, Culture=neutral" />
<!-- Uncomment this element when AddressFilter mismatch at the EndpointDispatcher happens
<AddressFilterModeAny/>-->
</behavior>
</serviceBehaviors>
</behaviors>
</system.serviceModel>
adlaws1
(Andrew Laws)
December 23, 2020, 11:32am
8
When i create the reference in visual studio i get the following screens
adaniell
(Adam)
December 23, 2020, 2:12pm
11
Your server’s SSL certificate might be too rigid, does it include an asterisk for subdomains?
If this is for development purposes, you may be able to bypass this by declaring the following in your code prior to making any requests:
if(Development)
ServicePointManager.ServerCertificateValidationCallback += (o, c, ch, er) => true;
Warning: The above code bypasses the client side validation done in your calling code, basically breaking SSL. This should only be used for development.
adlaws1
(Andrew Laws)
December 23, 2020, 2:42pm
12
i will try the above “after Christmas now” i believe it is a cert issue, unfortunately i have only just taken ownership of our new Epicor ERP project and we are still in implementation sprint, so its a bit of a learning curve by very impressed with the functionality of Epicor in the whole week i have been working with it
At the end of the protocol mapping node in your web.config, there is 2 remove tags, one for http and one for https. What happens if you remove those? I checked a working web.config on one of my servers, and mine does not end the protocol mapping node with remove tags.
adlaws1
(Andrew Laws)
December 28, 2020, 11:01am
14
Hi all
removed the tags from my web config and replaced the code with
if(Development)
and still not working, any more ideas what this could be ???/
adlaws1
(Andrew Laws)
December 28, 2020, 11:36am
16
I have noticed the endpoints dont seem to be set in the admin console, could this be the issues
Andy
adlaws1
(Andrew Laws)
December 28, 2020, 12:05pm
17
when i remove the following 2 tags
Exception caught in: mscorlib
Error Detail ============ Message:
The requested service, ‘net.tcp://e10server3/EpicorERPTest/Ice/Lib/SessionMod.svc’ could not be activated. See the server’s diagnostic trace logs for more information. Program: CommonLanguageRuntimeLibrary Method:HandleReturnMessage
Client Stack Trace
Looks like a cert issue then.
Get the subject name of your cert, and uncomment the node under serviceBehaviors / behaviors in your web.config .
You might also need to assign the cert to a binding in your IIS site. In IIS, make sure the site has a https binding and that the cert is assigned to that binding.
You might also need to set the cert
adlaws1
(Andrew Laws)
December 29, 2020, 1:52pm
19
After days and days i still could not connect so just made a reference to the dlls direct as so
static void TestUsingPartContract()
var wcfBinding = NetTcp.UsernameWindowsChannel();
var appServer = new Uri("net.tcp://localhost/EpicorERPTest/ERP/BO/Part.svc");
using (ChannelFactory<Erp.Contracts.PartSvcContract> cf = new ChannelFactory<Erp.Contracts.PartSvcContract> (wcfBinding))
cf.Credentials.UserName.UserName = "";
cf.Credentials.UserName.Password = "";
var partClient = cf.CreateChannel(new EndpointAddress(appServer));
bool morePages;
var myPartTableset = partClient.GetList("", 10, 1, out morePages);
foreach (var partRec in myPartTableset.PartList)
MessageBox.Show(partRec.PartNum + " desc =" + partRec.PartDescription);
cf.Close();
Olga
(Olga Klimova)
December 29, 2020, 4:46pm
20
If this is still the error you have, open event viewer on your server machine and look for exact error. Check application log and epicor app server log. What error is shown there?
