fyi
Sent: Tuesday, November 13, 2001 11:15 AM
Subject: RE: [Vantage] AP Debit Memo - apply to Invoices?
The more appropriate route we be to do an AP Adjustment for the 80+ invoices
you want to clear. Do the following.
1. Adjust them to a clearing account and put in the explanation/notes
area what Debit Memo number you are applying them against and why.
2. Take the sum of all the invoices and do one AP Adjustment against the
Debit Memo, putting it to the same clearing account. In the note section of
the Adjustment screen indicated which invoices you are applied to the Debit
Memo.
3. This will leave the Debit Memo with the remaining balance.
4. Any time you receive a new invoice from that vendor enter it into
Accounts Payable and do an adjustment against the remaining Debit Memo
balance until you have consumed the entire amount. Follow steps 1 through 3
above.
The Debit Memo balance will continue to show on your aging report until it
is consumed , the invoices will show as paid with the Debit Memo number in
place of the check. In addition you will have an appropriate audit trail.
You will not need to make any adjusting entries, because the Debit Memo
should have been put against the account that represents the the credit
whether expense or COGs. The adjustments need to go to a clearing account
because they do not represent a reduction in expense, but the payment of
invoices through the Debit Memo. The appropriate amounts from the Debit
Memo will wash each other out each time you do this, just as if you were
applying cash to the AP invoices.
Give me a call at the toll free number below if you have any questions and I
will go over it with you. Thanks.
Cameron A. Janish
Misha1
866-464-7421
cameron@...
Sent: Tuesday, November 13, 2001 10:33 AM
Subject: Re: [Vantage] AP Debit Memo - apply to Invoices?
Looks like what we are going to do is take 20 invoices at a time and
create a Debit Memo to match the totals of the 20, then print a $0 check.
Then we will reduce the $266K DM by that amount. I didn't realize we have
about 80 invoices, some of them 6 months old. We want to clean up the Aged
Payables report, and the vendor won't issue a check in this circumstance.
Thanks for your input Deb and Jim.
Troy Funte
Liberty Electronics
Memo.
above.
Cameron A. Janish
Misha1
866-464-7421
cameron@...
Troy Funte
Liberty Electronics
----- Original Message ----- v
Sent: Tuesday, November 13, 2001 11:40 AM
Subject: [Vantage] AP Debit Memo - apply to Invoices?
I need some help from the Bean Counters among us... my brain doesn't
work in the accounting area...
We have a Vendor who has issued us a credit of $266,000 which is in our
(5.0) system as a Debit Memo. We have 20 some invoices which don't even
come close to the amount of the Debit Memo. We would like to apply the
Debit Memo to some of these outstanding Payable invoices.
I know this can be done on the AR side, but is there a way to do this on
the AP side?
Thanks.
Troy Funte
Liberty Electronics
Yahoo! Groups Sponsor
