Been there- done that - I have 19,000 BOMs of which I've used 9000 in
2006-2007. Likewise I have 22,000 part numbers of which I've used 9500 in
2006-2007; and similar ratios on Customers and Vendors. Hence the term
House Cleaning is - well let's say appropriate?
_____
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of
Paul V. Blais
Sent: Monday, April 30, 2007 10:50 AM
To:
Subject: RE: [Vantage] Re: anyone tried starting from 8.0.3 to go live?
Of the 9000 BOM's how many are actually active and do you currently use?
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Stan Chmura
Sent: Monday, April 30, 2007 10:24 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
You can convert a 6.1 database, but in two years of testing I found that
it
does not covert very well. The most significant change that does not
lend
itself well to converting 6.1 data is that the work centers in 6.1
become
resources and resource groups in 8.x. So the structure of the methods
master (with respect to the work centers and operations) is completely
redesigned. I know that if I convert data I will need to redo all of my
9000 Methods Masters. Knowing that, I too am considering the option of
using this as an opportunity for some house cleaning and starting fresh.
_____
<mailto:vantage%40yahoogroups.com> ] On
Behalf Of
crypticsphere
Sent: Monday, April 30, 2007 9:49 AM
Subject: [Vantage] Re: anyone tried starting from 8.0.3 to go live?
Pretty much a question, we currently have a 6.10 running, just
wondering if I put 8.0.3 on a new server and move the database to the
new server would that work? Since it would convert the database as I
moved it to the new server right?
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
"Todd
Caughey" <caugheyt@...> wrote:
> Just curious....who is having you install 6 (or 6.1) at a new site
gojng to 8.03 - who is "they"? Does not make sense. For that matter
neither does 8.0 if you are going to run 8.03 and load new data.
> We are wavering on converting our 6.1 data and given the need to
change our Chart of Accounts and the ongoing discussion of BOM issues
requiring extensive manual intervention anyway so we are now leaning
towards a clean fresh start. So we would be doing the equivalent of a
new site and likely straight to 8.03.400 or pre-9 or 9 or whatever the
latest release is at the time.
> -Todd C.
> -----Original Message-----
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]On
Behalf Of crypticsphere
> Sent: Monday, April 30, 2007 6:37 AM
> Subject: [Vantage] anyone tried starting from 8.0.3 to go live?
> I was wondering, if anyone started at 8.0.3 without going through all
> the upgrades to get to 8.0.3. Wouldn't it make more sense that you
> could start at 8.0.3? If I was a new company coming to vantage, why
> would they have me install 6 then 8 then 8.0.3? There has to be some
> way to install this software directly is there not?
> James
