Any way to delete Part Transactions? NEED HELP
If the receipt is in error, just delete the packing slip and it will reverse the transaction.
Looks like that was already done, since every transaction by part nets 0.
What do they need to be deleted?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Monday, October 21, 2013 4:45 PM
To: Vantage
Subject: Re: [Vantage] RE: Any way to delete Part Transactions? NEED HELP
Just do a QA, you should NEVER delete transactions from the PartTran table.
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Mon, Oct 21, 2013 at 5:38 PM, <ralmon@...> wrote:
Need a way to clean these transactions out of the database ASAP!!! Anyone know a way to do this? The original transaction occurred in April and May and then one today from me deleting the assocaited transactions.
Sys Date
Sys Time
Tran
Part
Warehouse
Bin
Type
Type
Invty
Tran Date
Quantity
UOM
Mtl Unit Cost
Lbr Unit Cost
Bur Unit Cost
Sub Unit Cost
Mtl Bur Unit Cost
Amount
Costing Method
4/22/2013
35816
2
018F6813
SHOP
RECEIVING1
R
PUR-STK
TRUE
4/22/2013
2
EA
1000
0
0
0
0
2000
A
4/23/2013
35140
3
018F6813
SHOP
RECEIVING1
R
PUR-STK
TRUE
4/22/2013
-2
EA
1000
0
0
0
0
-2000
A
5/15/2013
26344
4
018F6813
SHOP
RECEIVING1
R
PUR-UKN
FALSE
5/15/2013
10
EA
2
0
0
0
0
20
A
5/15/2013
26345
5
020-202022
SHOP
RECEIVING1
R
PUR-UKN
FALSE
5/15/2013
10
EA
12
0
0
0
0
120
A
10/21/2013
59876
6
018F6813
SHOP
RECEIVING1
R
PUR-UKN
TRUE
5/15/2013
-10
EA
2
0
0
0
0
-20
A
10/21/2013
59876
7
020-202022
SHOP
RECEIVING1
R
PUR-UKN
TRUE
5/15/2013
-10
EA
12
0
0
0
0
-120
A
---In vantage@yahoogroups.com, <greg.bakker@...> wrote:
Greg,
I got the "rogue" UOM Class deleted by basically following what you suggested. I left the PartTrans alone. I edited the Part table through SQL and changed the UOMClassID to a different UOM Class. I was then able to delete the "rogue" UOM Class. I did some testing and everything seems to be working OK. If this was a production database I would be more hesitant to do this, but since it is a Pilot with almost no transactions I feel pretty safe.
Thanks for everyone's suggestions (and warnings). I appreciate it. I hope I can "pay it forward" some day!
Greg Bakker
Kooima Company
--- In vantage@yahoogroups.com, Greg Payne wrote:
> Greg:
> You can change the part uomclassid thru a sql query. That will enable you to delete the UOM Class. I would not delete the part trans, but change the partnum to another part and then you can delete the part. The cost adjustments will done on that part, but will be overridden when you add your current costs and quantities.
> all of this is predicated on no quantity transactions ever happening on the part.
> as Jose suggests backup before and test after you do this.
> Greg Payne
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of greg_bakker
> Sent: Friday, January 04, 2013 11:31 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Any way to delete Part Transactions?
> We are about 75% through our initial implementation of Epicor 9.05.701. We are working on setting up our Pilot (pristine) environment. There somehow got a Part in there with a couple of transactions against it (ADJ-CST). I would like to delete this Part because it is using a UOM Class that I would like to delete. But it will not let me delete either the UOM Class or the Part because of the transactions against that Part. Epicor Support basically told be that there is no way to delete these transactions so I need to mark the Part and UOM Class as Inactive.
> So, I guess before I resort to that, I thought I would ask if any of you know if there is a way I can safely delete these transactions/Part/UOM Class? It looks like these transactions happened about 5 months ago, so I can't restore a db backup, too much has changed since then.
> What is the worst thing that would happen if I just deleted those two transaction records out of the PartTran table through SQL? We don't have any history in this Pilot database yet that could get messed up. I don't think many of the GL Control Codes were even set up when the transactions took place. FYI: In these PartTran records GLTrans=1 and PostedToGL=0. Any words of wisdom?
> Thanks,
> Greg Bakker
> Kooima Company
> CONFIDENTIALITY NOTICE
> The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
> "This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior approval form the U.S. Department of State."
Greg Bakker
Kooima Company
Take a Backup first :)
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
> words of wisdom?
> Thanks,
> Greg Bakker
> Kooima Company
Greg,
Unless you are an expert with the schema, deleting the PartTran record would be highly unadvisable. I don�t know what the transaction was posted to, but for example, if it was posted as a material to a job then the costs would also roll up the job materials and job head table. Similar roll ups would occur if it was an inventory transaction. If any of these types of related transactions have occurred, in addition to the GL, deleting the PartTran record would damage the relational integrity of the DB and create a GAAP violation because you could not trace the rolled up values back to the transactions.
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
http://www.aspacia.com/
This email, and any attachments thereto, is intended only for use by the addressee(s) named herein and may contain legally privileged and/or confidential information. If you are not the intended recipient of this email, you are hereby notified that any dissemination, distribution or copying of this email, and any attachments thereto, is strictly prohibited. If you have received this email in error, please immediately notify me by telephone and permanently delete the original and any copy of any email and any printout thereof.
> Thanks,
> Greg Bakker
> Kooima Company
I would agree on the severity of deleting the transactions.
It looks like it was just a cost adjustment but I would capture and post
this transaction and then journal entry it off the books, if needed.
Joe Rojas | Director of Information Technology | Mats Inc
dir: 781-573-0291 | cell: 781-408-9278 | fax: 781-232-5191
jrojas@... | www.matsinc.com Ask us about our clean, green and beautiful matting and flooring
This message is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company.
Of Michael Barry
Sent: Friday, January 04, 2013 1:25 PM
Subject: Re: [Vantage] Any way to delete Part Transactions?
Greg,
would be highly unadvisable. I don't know what the transaction was
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
since then.
> Thanks,
> Greg Bakker
> Kooima Company
The PartTran table has indexes to many tables and now with Epicor 9 - the
intermediate table between the PartTran and TranGLC tables.
If it that important maybe Epicor could supply a script to remove these
records.
I would not try it on my own.
Joe Rojas
Sent: Friday, January 04, 2013 11:32 AM
Subject: RE: [Vantage] Any way to delete Part Transactions?
jrojas@... <mailto:jrojas%40matsinc.com> | www.matsinc.com Ask us
of the company.
Behalf
Of Michael Barry
Greg,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
On Jan 4, 2013, at 8:30 AM, greg_bakker greg.bakker@...
since then.
> Thanks,
> Greg Bakker
> Kooima Company
Greg:
Greg Payne
Greg Bakker
Kooima Company
If the part has just ADJ-CST transactions and PartTran.ExtCost is zero, then you can think of deleting the PartTran as GL transactions (tables like TranGlc and GLJrnDtl) are not created for zero cost transactions during Capture COS/WIP run. This must be a last option as you need to weigh the option of going with the new part or using the existing part by deleting the PartTran. If you wish to go with deleting PartTran, make sure that cost of the part is zero in this case as PartCost table will have non-zero value without releated PartTran. Before deleting any record it's advisble to write the data into a file so that it can be loaded back if it's required. But if the part has any other transaction type then don't even think of deleting PartTran. Try this in the test system and if you are happy with the result, then do it in live. Â
Â
Regards,
Arul
Sent: Saturday, 5 January 2013 5:58 AM
Â
records.
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com] On Behalf Of
Joe Rojas
To: mailto:vantage%40yahoogroups.com
mailto:jrojas%40matsinc.com | www.matsinc.com Ask us
of the company.
[mailto:mailto:vantage%40yahoogroups.com ] On
Behalf
Of Michael Barry
Greg,
Michael
Michael Barry
Aspacia Systems Inc
866.566.9600
312.803.0730 fax
On Jan 4, 2013, at 8:30 AM, greg_bakker mailto:greg.bakker%40kooima.com
since then.
> Thanks,
> Greg Bakker
> Kooima Company
I had heard that Epicor had created a means of changing the UOM Class and Inventory UOM.
If you could get this patch (fix) from Epicor it would work better for you I would think.
Has anyone been able to get this fix?
Bruce
--- In vantage@yahoogroups.com, Arul Shankar wrote:
> If the part has just ADJ-CST transactions and PartTran.ExtCost is zero, then you can think of deleting the PartTran as GL transactions (tables like TranGlc and GLJrnDtl) are not created for zero cost transactions during Capture COS/WIP run. This must be a last option as you need to weigh the option of going with the new part or using the existing part by deleting the PartTran. If you wish to go with deleting PartTran, make sure that cost of the part is zero in this case as PartCost table will have non-zero value without releated PartTran. Before deleting any record it's advisble to write the data into a file so that it can be loaded back if it's required. But if the part has any other transaction type then don't even think of deleting PartTran. Try this in the test system and if you are happy with the result, then do it in live. ÂÂ
> ÂÂ
> Regards,
> Arul
> From: Cathy
> ÂÂ
> records.
> Joe Rojas
> of the company.
> Behalf
> Of Michael Barry
> Greg,
> Michael
> Michael Barry
> Aspacia Systems Inc
> 866.566.9600
> 312.803.0730 fax
> since then.
> > Thanks,
> > Greg Bakker
> > Kooima Company
If you don't have any of the part in inventory, orders, incoming POs etc,
you can change it in the DB pretty safely. Not exactly the recommended
method, but it can be done.
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> Inventory UOM.
> I would think.
> Bruce
> > If the part has� just ADJ-CST transactions and PartTran.ExtCost is zero,
> then� you can think of deleting the PartTran� as GL transactions (tables
> during Capture COS/WIP run.� This must be a last option as you need to
> deleting the PartTran.� If you wish to go with deleting PartTran, make sure
> that cost of the part is zero in this case as PartCost table� will� have
> non-zero value without� releated PartTran.� Before deleting any record it's
> even think� of deleting PartTran. Try this in the test system and if you
> are happy with the result, then do it in live.� �
> > Regards,
> > Arul
> > From: Cathy
> > records.
> > Joe Rojas
> the
> e-mail.
> this
> those
> > of the company.
> > Behalf
> > Of Michael Barry
> > Greg,
> > Michael
> > Michael Barry
> > Aspacia Systems Inc
> > 866.566.9600
> > 312.803.0730 fax
> > since then.
> > > Thanks,
> > > Greg Bakker
> > > Kooima Company
Greg,
Greg Bakker
Kooima Company
> Greg:
> Greg Payne
> Thanks,
> Greg Bakker
> Kooima Company
Sys Date Sys Time Tran Part Warehouse Bin Type Type Invty Tran Date Quantity UOM Mtl Unit Cost Lbr Unit Cost Bur Unit Cost Sub Unit Cost Mtl Bur Unit Cost Amount Costing Method
4/22/2013 35816 2 018F6813 SHOP RECEIVING1 R PUR-STK TRUE 4/22/2013 2 EA 1000 0 0 0 0 2000 A
4/23/2013 35140 3 018F6813 SHOP RECEIVING1 R PUR-STK TRUE 4/22/2013 -2 EA 1000 0 0 0 0 -2000 A
5/15/2013 26344 4 018F6813 SHOP RECEIVING1 R PUR-UKN FALSE 5/15/2013 10 EA 2 0 0 0 0 20 A
5/15/2013 26345 5 020-202022 SHOP RECEIVING1 R PUR-UKN FALSE 5/15/2013 10 EA 12 0 0 0 0 120 A
10/21/2013 59876 6 018F6813 SHOP RECEIVING1 R PUR-UKN TRUE 5/15/2013 -10 EA 2 0 0 0 0 -20 A
10/21/2013 59876 7 020-202022 SHOP RECEIVING1 R PUR-UKN TRUE 5/15/2013 -10 EA 12 0 0 0 0 -120 A
Greg,
Greg Bakker
Kooima Company
> Greg:
> Greg Payne
> Thanks,
> Greg Bakker
> Kooima Company
Jose C Gomez
Software Engineer
E: jose@…
     Â
Â
<div>
  <p></p><p>Need a way to clean these transactions out of the database ASAP!!! Anyone know a way to do this? The original transaction occurred in April and May and then one today from me deleting the assocaited transactions. </p>
Â
Greg,
Greg Bakker
Kooima Company
> Greg:
> Greg Payne
> Thanks,
> Greg Bakker
> Kooima Company
</div>
<div style="color:#fff;min-height:0;"></div>
