I am part of a project to start using serialization in Epicor as well as the DMR system.
We currently are performing those two functions using excel sheets and finally have the momentum to start using Epicor the way it was designed!
One of the things I will be purchasing or creating is something similar to this:
where it allows you to easily DMR multiple serial numbers for different DMR reasons at the same time.
Any recommendations for other custom interfaces or fields to streamline the process?
Has anyone run into issues implementing either of these in an existing Epicor process?
