If you have this:
Volume:
- CUFT
- DR
- GAL
- L
- ML
- OZ
- PT
- QT
Count:
- EA
- PC
- SHT
And you want to go from OZ to EA… (don’t care about any other conversion):
You still need:
Other: (Now you are putting in all UOMs into this Class, so the program doesn’t freak out when it doesn’t see a “CUFT”, I know we are not converting to CUFT or using CUFT, but the Program is written in a way where it requires the merged UOMs of 2 Classes into 1 Class.
- CUFT
- DR
- GAL
- L
- ML
- OZ
- PT
- QT
- EA
- PC
- SHT
That’s what I understood thus far… The program was meant for UOM Conversion, yet when you are attempting to jump “Classes” as well, you need a combined Class with all UOMs so it can convert… Is that correct?
In addition any other hints/tips or even Any DataFixes known to assist converting a Part with a handful only of ADJ-CST Transactions.
