Any backdoor method to fix a standard RDD
Still no luck. The solution manager acts like it is doing something on install but then I cannot find the new report data definition.
--- In vantage@yahoogroups.com, John Driggers <waffqle@...> wrote:
> On 9.04+ you can import/export RDDs using the Solution Manager.
> What you'll probably want to do is open the stock RDD in the editor and
> duplicate it. Then you can import the 'custom' RDD you just created into
> the new system. You'll need to create a custom report style to use it as
> well.
> That said, it should work.
> If it's choking on that, let me know what the error is and I'll see if I
> can help.
> *John Driggers*
> *Chief Data Wrangler*
> *I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
> *:: 904.404.9233
> :: waffqle@...
> :: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> On Fri, Jul 6, 2012 at 10:09 AM, Rob Bucek <rbucek@...> wrote:
> > Why they don't support import/export of custom RDD's is completely
> > unfathomable..
> > Rob Bucek
> > Production Control Manager
> > PH: (715) 284-5376 ext 311
> > Mobile: (715)896-0590
> > FAX: (715)284-4084
> > [Description: cid:1.234354861@...]<
> > http://www.dsmfg.com/>
> > (Click the logo to view our site)<http://www.dsmfg.com/>
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of Nancy
> > Sent: Friday, July 06, 2012 9:01 AM
> > Subject: [Vantage] Any backdoor method to fix a standard RDD
> > Hi there,
> > We recently went from 904506 to 905607B. With it, we lost our ability to
> > create a full indented bill of material listing which shows lower levels
> > for parts that are manufactured in plant other than the top level one. The
> > standard BOM listing in teh 904506 version worked fine.
> > Does anyone have any ideas for how to get a standard report from 904
> > version imported / brought into the new 905 upgrade? I've tried to import
> > solution, and faked out the version number, but it's not working. If only I
> > could import a report data definition, plain and simple...
> > Thanks for your consideration,
> > Nancy
> > PS: Epicor support claims it is intentional and "by design"; we really
> > need to start considering dropping this crappy maintenance contract.
Hi there,
We recently went from 904506 to 905607B. With it, we lost our ability to create a full indented bill of material listing which shows lower levels for parts that are manufactured in plant other than the top level one. The standard BOM listing in teh 904506 version worked fine.
Does anyone have any ideas for how to get a standard report from 904 version imported / brought into the new 905 upgrade? I've tried to import solution, and faked out the version number, but it's not working. If only I could import a report data definition, plain and simple...
Nancy
PS: Epicor support claims it is intentional and "by design"; we really need to start considering dropping this crappy maintenance contract.
Why they don't support import/export of custom RDD's is completely unfathomable..
Rob Bucek
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Nancy
Hi there,
Nancy
well.
can help.
*John Driggers*
*:: 904.404.9233
:: waffqle@...
> unfathomable..
> Rob Bucek
> FAX: (715)284-4084
> Of Nancy
> Hi there,
> Nancy
