Another problem with 5.2 upgrade
You should be able to change parts in Engineering Workbench with out having
them hang as long as you do not resquence the operations OR re-use a
previously used (and deleted) operation sequence number. This makes for odd
looking routings with gaps in numbering but the infinite looping is caused
when a sequence number is re-used. If you have parts "stuck" in there not
being able to be checked back in you can delete the changes, check it in,
check it back out and remake the changes without re-using a sequence number.
This is the workaround we are currently using until a safe patch is
available. This issue was to be fixed in the forst .3xx level patch (303?)
that was recalled for other issues.
-Todd C.
[mailto:michael.j.moloney@...]
Sent: Wednesday, December 18, 2002 9:44 AM
Subject: RE: [Vantage] Another problem with 5.2 upgrade
We upgraded and went "Live" on Version 5.2 on November 18th and have had
our share of problems. We are unable to create and print "Bill of Ladings"
because it pulls the wrong address, the Visual Scheduling Board takes
forever to refresh when you expand a job to view the operations, If you
print a group of invoices it numbers them in order (but doesn;t reset with
the invoice number"), Parts get hung up in the Engineering Workbench (so we
are not able to make any changes to them in the parts master), the new Role
table created a nightmare with my reports concerning Quoters and
Salespersons, if you start a new quote and pick a contact from one of the
"ship to" locations they are not the one that shows up on the quote (it's
someone not even associated with the quote), we are having trouble printing
quotes to Adobe Acrobat, just to mention a few.
We are still on 5.20.212 and are scared to death to install the next patch.
Mike Moloney
AR Industries
(Embedded Gary Wassing <gwassing@...>
image moved 12/18/2002 09:15 AM
to file:
pic24494.pcx)
Please respond to vantage@yahoogroups.com
To: "'vantage@yahoogroups.com'" <vantage@yahoogroups.com>
cc: (bcc: Michael J. Moloney/USWIN01/Power/ALSTOM)
Security Level:? Internal
We upgraded to 5.2 on the 23rd of November. I have to be honest, it has
been nothing but a pain in the a** since then. Out of all the problems,
the
3 biggest would be PO Suggestions that tell you to purchase when you
already
have stock; AP invoice entry; and ODBC doesn't release the license when you
print so you get an error 0 when you run out of licenses. This is just a
few problems so far and they seem to keep popping up everyday. Had I known
I might have skipped the upgrade too. By the way does anybody have Mike's
email so I can get the timeout utility. I will go thru the archives for it
but I've been too busy fixing errors.
Gary Wassing
MIS
SteelCraft Industries
519-271-4750
Sent: Tuesday, December 17, 2002 12:16 PM
To: Vantage Group (E-mail)
Subject: [Vantage] Another problem with 5.2 upgrade
We upgraded to 5.2 on Oct. 26. We are no longer getting the cost of scrap
on
the Production Detail Report. Seems this was discontinued on Version 5.2.
The problem is being submitted to development and support will let me know
what development says. In the meantime, we cannot retrieve the cost of
scrap
until Vantage puts the calculation back in.
Karen Brodniak
Accounting Manager
Phone: 425-742-7011 x44
Fax: 425-353-8945
karen.brodniak@...
<http://docs.yahoo.com/info/terms/>
We upgraded to 5.2 on Oct. 26. We are no longer getting the cost of scrap on
what development says. In the meantime, we cannot retrieve the cost of scrap
Karen Brodniak
Accounting Manager
Fax: 425-353-8945
karen.brodniak@...
been nothing but a pain in the a** since then. Out of all the problems, the
3 biggest would be PO Suggestions that tell you to purchase when you already
Gary Wassing
MIS
519-271-4750
Karen Brodniak
Accounting Manager
Fax: 425-353-8945
karen.brodniak@...
We solved the exact ODBC issues that you are referring to by placing the v8
Crystal DLL files in the \Vantage\DLL directory. These errors are caused by
the v8.5 DLL files that shipped with Vantage.
Ted Kitch
ted@...
Sent: Wednesday, December 18, 2002 8:16 AM
To: 'vantage@yahoogroups.com'
Gary Wassing
MIS
519-271-4750
Karen Brodniak
Accounting Manager
Fax: 425-353-8945
karen.brodniak@...
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
Mike Moloney
AR Industries
to file:
pic24494.pcx)
the
already
Gary Wassing
MIS
519-271-4750
on
scrap
Karen Brodniak
Accounting Manager
Fax: 425-353-8945
karen.brodniak@...
CONFIDENTIALITY : This e-mail and any attachments are confidential
and may be privileged. If you are not a named recipient, please
notify the sender immediately and do not open any attachments hereto,
disclose the contents of this e-mail or the attachments if any
thereto, to another person, use it for any purpose or store or copy
the information in any medium.
