Another database question: create standard lead tim es: solutio
Paul, it's not so much of a joke - check out this link
http://www.cnn.com/2002/TECH/ptech/08/21/eye.writing/index.html
Norm Watkins
At 10:57 AM 8/23/02 -0400, you wrote:
>D'oh! same thing happened to me yesterday! Marketing walked into my cubicle
>and saw me staring at the screen while windows were popping up and under,
>text appeared out of nowhere in the fields, etc. When he asked me how I was
>doing that, I told him I was testing a new type flat panel screen
>(Coincidentally, I just got myself a nice Sony), that senses the position of
>the eye's pupils on the screen and directs the mouse and keyboard input
>accordingly. As of this morning he was still believing it, and was
>overheard pitching the idea to engineering for use on our product's touch
>screen panels. Engineering and I have collectively decided to hold off on
>informing marketing of the joke.
>Paul
>-----Original Message-----
>From: Shirley Graver [mailto:shirleyg@...]
>Sent: Friday, August 23, 2002 10:45 AM
>To: vantage@yahoogroups.com
>Subject: RE: [Vantage] Another database question: create standard lead
>times: solution!
>I like macro express too. The only thing I found is that at high speed you
>get a little bit of screen creep, and it misses. I usually run things in
>100 record batchs. Whats fun is when users come in they think I'm just
>THINKING about it and it works. Adds to the mystique. :)
>Shirley
> From: Paul Siebers [mailto:paul.siebers@...]
> Sent: Friday, August 23, 2002 9:57 AM
> To: 'vantage@yahoogroups.com'
>times: solution!
> FYI, in case you ever find yourself in a similar situation...
> I found the perfect solution... Rather than diving manually into a
>Progress
> database and do a search and replace routine of some sorts, I went the old
> fashioned way of recording a macro.... I printed all the part numbers
>that
> had to have their lead time changed from 0 to 9 days to an Excel sheet.
> While the part master is open in the background, I copy the contents of
>the
> first cell into the part number field, go to the Inv/Pur screen, update
>the
> lead time field, switch back to the excel sheet and delete the entire
>first
> row. This causes all the part numbers to shift and the next number is
>ready
> to be copied. "Goto 10", and the entire sequence repeats itself over
>again
> ad infinitum. I am using Macro Express, which allows you easy control of
> the speed. I found that Vantage hicks up every now and then when you work
> it at 10 times the speed of a human, I tweaked the speed back to 8 times
>the
> speed, and it seems to work fine.
> Paul
> From: Paul Siebers
> Sent: Wednesday, August 21, 2002 1:01 PM
> tim es
> All,
> Is there a way to do a global replace of the lead time field only for
> purchased parts that have a lead time of 0 days? The prospect of doing it
> manually does not seem too inviting for me on a 35K+ parts database....
> TIA,
> Paul
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
>have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
>Crystal Reports and other 'goodies', please goto:
>http://groups.yahoo.com/group/vantage/files/.
>http://groups.yahoo.com/group/vantage/messages
>http://groups.yahoo.com/group/vantage/links
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
>[Non-text portions of this message have been removed]
>Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Norm Watkins
Engineering Mgr.
ELECPAC
Phone: 847-639-2307
I found the perfect solution... Rather than diving manually into a Progress
fashioned way of recording a macro.... I printed all the part numbers that
While the part master is open in the background, I copy the contents of the
first cell into the part number field, go to the Inv/Pur screen, update the
lead time field, switch back to the excel sheet and delete the entire first
row. This causes all the part numbers to shift and the next number is ready
to be copied. "Goto 10", and the entire sequence repeats itself over again
it at 10 times the speed of a human, I tweaked the speed back to 8 times the
Paul
tim es
All,
TIA,
Paul
Shirley
times: solution!
Progress
that
the
the
first
ready
again
the
Paul
tim es
All,
TIA,
Paul
ADVERTISEMENT
Paul
times: solution!
Shirley
times: solution!
Progress
that
the
the
first
ready
again
the
Paul
tim es
All,
TIA,
Paul
ADVERTISEMENT
I used the same method to enter all of our data when we converted from an
AS400 to Vantage. One thought I would share is if you use Winbatch.
www.winbatch.com you can set it up to wait till a screen is open. They
have a command that goes something like waitwinexist("Purchase Order
Entry"). This really helps with the timing issue.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Friday, August 23, 2002 8:57 AM
tim es: solution!
Paul
tim es
All,
TIA,
Paul
