Alternate Report Styles In Epicor 9
I have 2 Crystal reports. One is the current Pack Slip the other is going to be an alternate style for a select group of customers. This Alternate report style will be triggered by a field in the customer table.
Here is my situation:
I have added both reports as styles to the Pack Report Style - if I do not set up the alternate report style and select each one then they work fine. If I add the table and field to the “Report Routing” tab in the data def and setup the Alternate report style - both reports come back blank (They do use the same Data Def).
  • I have verified that the XML that is created is adding the report link and Report Routing information correctly (from what I can tell)
Question: Has anyone come across this before? Is there something I need to add to the crystal reports?
