Maybe a bad idea and off topic but I would also like to be able to use other BAQs in another BAQ. For example, a BAQ that always returns the most current revision of a Part. I use that over and over in other BAQs but I have to rewrite that subquery for each new one. Maybe there is a different way to approach this to make it easier??
Split into its own topic.
I can’t believe this wasn’t already in the list! I even looked to see if it was.
The ability to nest a BAQ within a BAQ would be greatly appreciated. Currently one has to go about this by going into SSMS and creating a custom View, then link up the View to the BAQ via External BAQ with an External Data Source that simply points back to the same local database.
That’s already been requested.
