All reports with routing, even if unchecked on print screen, don't print via server printer
Suddenly our custom SSRS reports stopped printing through server printing, however, the stock one prints through server printing. Both show complete in system monitor and both open fine in preview.
Any thoughts?
Okay, more details on this… it seems to be only our custom SSRS reports that have routing.
  • If I disable routing on the print screen and send to a server printer, no print.
  • If I DELETE ALL elements in breaking/routing, and disable routing on the print screen and send to a server printer, no print.
  • If I disable breaking/routing on the report style, then send to a server printer, it will print
  • If I copy the report style with routing, uncheck routing on print screen, no print
  • If I disable routing for this copied style, and send to server printer, it will print
… so confused.
When a report fails to print, what is showing in the System Monitor?
Normal flow would be:
  1. A task appears on the scheduled tab
  2. Task is moved to the Active tab
  3. Entry appears in the History tab
  4. Entry exists in the Reports tab. This won’t happen if the result in the History tab shows ERROR.
