Alert Program? (Version 6.1)
Huh?
Tanya Jernigan, V.P.
tjernigan@... <mailto:tjernigan@...>
www.waterjetparts.com <http://www.waterjetparts.com/>
H2O Jet, Inc.
1043-D Kaiser Rd. SW
Olympia, WA 98512
360-866-7161 Phone
360-866-7610 Fax
_____
Of Podlin, Michael
Sent: Thursday, June 08, 2006 2:09 PM
Subject: RE: [Vantage] Alert Program? (Version 6.1)
The only thing the BAM is giving vs my Automated report is that the BAM
can occur the instance a change takes place, with my Automated Report, a
.P procedure is executed at 3am each day compiling all the "past due"
information into a htm file which is then pushed to the Autoreports
e-mail engine and sent to the responsible people. Not real time, but
within 24 hrs.... (and it allows me to create a list of items vs one
e-mail for each item)
If you really wanted something to actually trigger off a BAM, you could
use a VBForm field which the BAM fires off of. You'll then need to
create a .W application with a pstimer.ocx which will trigger every x
seconds running a query against your date values. Items that become past
due, the .W application would then update the VBForm field value that
should trigger the BAM. Down side is that you'll have to execute this
inside an open session of Vantage which will use up one of your
licenses.
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
Behalf Of Kennedy, Jim
Sent: Thursday, June 08, 2006 3:56 PM
I do already have all of those reports created using Excel & MS Query
(linked via ODBC), and they're setup to "Refresh on file open," but of
course my GM requested that I give my lazy co-managers more of a nudge.
Thus the thought of finding a way to trigger the BAM...
_____________________________
Jim Kennedy
Manager, Information Technologies
Firstmark Aerospace Corporation
1176 Telecom Drive
Creedmoor, North Carolina 27752
Office: (919) 956-4264
FAX: (919) 682-3786
Cell: (919) 697-9410
jkennedy@firstmarka <mailto:jkennedy%40firstmarkaerospace.com>
erospace.com <mailto: jkennedy@firstmarka
<mailto:jkennedy%40firstmarkaerospace.com> erospace.com>
www.firstmarkaerospace.com < http://www.firstmar
<http://www.firstmarkaerospace.com/ <http://www.firstmarkaerospace.com/>
> kaerospace.com/>
www.firstmarkcorp.com < http://www.firstmar
<http://www.firstmarkcorp.com/ <http://www.firstmarkcorp.com/> >
kcorp.com/>
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Podlin, Michael
Sent: Thursday, June 08, 2006 4:25 PM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
What I do is execute automated reports with time/date filters on a daily
basis which are e-mailed to the people responsible or need to be aware
of late/past due items.
Behalf Of Aaron Hoyt
Sent: Thursday, June 08, 2006 2:10 PM
Jim,
Unless I am mistaken, this is one of the limitations of the BAM (alert
program). The BAM must see a change is a field, but can't be triggered
just
by time going by.
Please let me know if someone has found another method around this.
Aaron Hoyt
Vantage Plastics
[mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]On
Behalf Of
Kennedy, Jim
Sent: Thursday, June 08, 2006 11:35 AM
Subject: [Vantage] Alert Program? (Version 6.1)
Hello,
Has anyone got a quick example of an alert program (progress file) you
may
have developed to trigger based on the calculated age of a value in a
date
field?
Just looking for a quick shortcut...
Thanks in advance,
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
erospace.com
< http://www.firstmar <http://www.firstmarkaerospace.com/
<http://www.firstmarkaerospace.com/> > kaerospace.com/ <
<http://www.firstmarkaerospace.com/> > kaerospace.com/>
> kaerospace.com/>
< http://www.firstmar <http://www.firstmarkcorp.com/
<http://www.firstmarkcorp.com/> > kcorp.com/ < http://www.firstmar
kcorp.com/> >
kcorp.com/>
Hello,
Has anyone got a quick example of an alert program (progress file) you may have developed to trigger based on the calculated age of a value in a date field?
Thanks in advance,
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@...
www.firstmarkaerospace.com <http://www.firstmarkaerospace.com/>
www.firstmarkcorp.com <http://www.firstmarkcorp.com/>
Jim,
program). The BAM must see a change is a field, but can't be triggered just
by time going by.
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
Kennedy, Jim
Hello,
field?
Thanks in advance,
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@...
What I do is execute automated reports with time/date filters on a daily basis which are e-mailed to the people responsible or need to be aware of late/past due items.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Aaron Hoyt
Jim,
by time going by.
Aaron Hoyt
Vantage Plastics
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com]On Behalf Of
Kennedy, Jim
Hello,
field?
Thanks in advance,
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@firstmarka <mailto:jkennedy%40firstmarkaerospace.com> erospace.com
www.firstmarkaerospace.com < http://www.firstmar <http://www.firstmarkaerospace.com/> kaerospace.com/>
www.firstmarkcorp.com < http://www.firstmar <http://www.firstmarkcorp.com/> kcorp.com/>
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@... <mailto:jkennedy@...>
Of Podlin, Michael
Jim,
just
by time going by.
Aaron Hoyt
Vantage Plastics
Behalf Of
Kennedy, Jim
Hello,
may
date
field?
Thanks in advance,
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
erospace.com
> kaerospace.com/>
kcorp.com/>
The only thing the BAM is giving vs my Automated report is that the BAM can occur the instance a change takes place, with my Automated Report, a .P procedure is executed at 3am each day compiling all the "past due" information into a htm file which is then pushed to the Autoreports e-mail engine and sent to the responsible people. Not real time, but within 24 hrs.... (and it allows me to create a list of items vs one e-mail for each item)
If you really wanted something to actually trigger off a BAM, you could use a VBForm field which the BAM fires off of. You'll then need to create a .W application with a pstimer.ocx which will trigger every x seconds running a query against your date values. Items that become past due, the .W application would then update the VBForm field value that should trigger the BAM. Down side is that you'll have to execute this inside an open session of Vantage which will use up one of your licenses.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Kennedy, Jim
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
jkennedy@firstmarka <mailto:jkennedy%40firstmarkaerospace.com> erospace.com <mailto: jkennedy@firstmarka <mailto:jkennedy%40firstmarkaerospace.com> erospace.com>
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com [mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On Behalf
Of Podlin, Michael
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com>
[mailto: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com> ]On
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com <mailto:vantage%40yahoogroups.com>
Jim,
just
by time going by.
Aaron Hoyt
Vantage Plastics
Behalf Of
Kennedy, Jim
Hello,
may
date
field?
Thanks in advance,
Jim Kennedy
1176 Telecom Drive
FAX: (919) 682-3786
erospace.com
< http://www.firstmar <http://www.firstmarkaerospace.com/> kaerospace.com/ < http://www.firstmar <http://www.firstmarkaerospace.com/> kaerospace.com/>
> kaerospace.com/>
< http://www.firstmar <http://www.firstmarkcorp.com/> kcorp.com/ < http://www.firstmar <http://www.firstmarkcorp.com/> kcorp.com/> >
kcorp.com/>
