I would like to create a directive that will generate an alert every 12th record that is added to the dashboard. I originally did some experimentation with looking for multiple’s of 12 in the “Receiver” field, but there are some receiver numbers that are filtered out of the log so this logic doesn’t work. Here is my dashboard:
The alert is to tell the user to print the paper version of the log (an SSRS report) for our inspection stations that don’t have Epicor access. I can’t trigger an autoprint of the report since it is a baq report.
Tried unsuccessfully to autoprint here:
Any thoughts on how I can create a directive to pop up an alert??
I for one would need a bit more understanding how you would want this to work.
Epicor doesn’t add things to dashboards, as I’m sure you know. They appear in a dashboard because they’ve been added or changed in their base records. So should this happen out of sight when the twelfth item matching the criteria is created on the database, or for every twelfth row only when someone is looking at this dashboard?
