Aged Receivables report not working after upgrade
We have upgraded our test environment from 10.1.500 to 10.2.300.4. I tried to run the built in Aged Receivables report, but get an error that it cannot find the RptParameter table. Actually there are no tables created for the guid assigned to this instance of the report. I have a case open with Epicor, but not getting anywhere. The Datasource is working correctly. Other reports are working both built in and custom. Not sure yet if this is the only report that is not working. Any ideas?
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: An error has occurred during report processing. ---> Microsoft.ReportingServices.ReportProcessing.ProcessingAbortedException: An error has occurred during report processing. ---> Microsoft.ReportingServices.ReportProcessing.ReportProcessingException: Query execution failed for dataset 'RptParameter'. ---> System.Data.SqlClient.SqlException: Invalid object name 'RptParameter_6672aca6ebd54104801059f9274d8d63'.
Stack Trace:
   at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
   at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
   at Ice.Core.SsrsReportService.ReportExecutionService.SetExecutionParameters(ParameterValue[] Parameters, String ParameterLanguage) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\Web References\SsrsReportService\Reference.cs:line 497
   at Ice.Core.SsrsReporting.SsrsRendererBase.ConfigureReportServerForReport(String reportPath, ParameterValue[] parameters) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 163
   at Ice.Core.SsrsReporting.SsrsSingleDocumentRenderer.<>c__DisplayClass1_0.<RenderDocument>b__0() in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsSingleDocumentRenderer.cs:line 49
   at Ice.Core.SsrsReporting.SsrsRendererBase.<>c__DisplayClass12_0.<TraceReportRendered>b__0() in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 87
   at Epicor.Hosting.Trace.TraceHandle.TimeAction(Action actionToTime) in C:\_Releases\ICE\ICE3.2.300.4\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 92
   at Epicor.Hosting.Trace.TraceHandle.AddTimedIfEnabled(String traceFlag, Action actionToTime, Func`2 messageBuilder) in C:\_Releases\ICE\ICE3.2.300.4\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 39
   at Ice.Core.SsrsReporting.SsrsRendererBase.TraceReportRendered(String printProgram, String ssrsRenderFormat, Func`1 timedAction) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 95
   at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReportForPreviewOrGenerate(RenderedSsrsReport renderedReport) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 264
   at Ice.Core.SsrsReporting.ReportProcessorBase.ProcessReportPart(String reportLocation) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 158
   at Ice.Core.SsrsReporting.StandardReportProcessor.ProcessReportParts() in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\SsrsReporting\StandardReportProcessor.cs:line 31
   at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(ReportInstanceInformation reportInstance, Func`2 reportsRenderer, Action`1 fillSysRptLstRow, Action`2 processReport, Func`3 filterTableAttachmentsFunc) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 57
   at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RenderUnroutedSsrsReport() in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 303
   at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RunSsrsReportIfEnabled() in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 228
   at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.ProcessReportWithDataInPlace(Func`2 executeCommand, Func`2 executeReader, SqlObjectsCreated sqlObjectsCreated) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 111
   at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 93
   at Ice.Core.RptTaskBase`1.XMLClose() in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 216
   at Erp.Internal.AR.AgedRecReport.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_projects\ERP\RL10.2.300.0\Source\Server\Internal\AR\AgedRecReport\AgedRecReport.cs:line 1523
   at Ice.Core.TaskBase`1.StartProcess(Int64 instanceTaskNum, String outputFileName) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 47
   at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in c:\_Releases\ICE\RL3.2.300.0\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 98
   at Ice.Hosting.TaskCaller.ExecuteTask() in c:\_Releases\ICE\RL3.2.300.0\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 57
   at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
   at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in c:\_Releases\ICE\RL3.2.300.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 577
Resolved. I re-installed the reports from the Admin Console and they are now working.
Had similar issue, but mine was in the Custom Folder. So I checked and the main form did not have the right Shared Data Source. Connected it the right service and it ran perfect!
