Yes, I just got confirmation this morning. I'm on SQL .408B and this is
a "known issue" that Support will send you a process to run/install.
Of cubcrafters_it
Sent: Wednesday, March 30, 2011 11:34 AM
Subject: [Vantage] Re: Aged Receivables Difference
We've got a similar issue, only with the Aged Payables report not
matching the GL, also revolving around credit adjustments. Running
8.03.409A Progress.
My accounting department told me there's a time limited fix that we
install (which seems a little weird to me, to be honest).
I've put a call into support for a fix yesterday, so we'll see what I
get.
Occasionally I have to run the 9527 conversion, but it's for a
completely different issue.
"laraines422" <laraines422@...> wrote:
on hold in error, because Vantage doesn't calculate the balances
correctly.
want to get confirmation from Epicor.
Of cubcrafters_it
8.03.409A Progress.
get.
>they have seen similar issues in Credit Manager. A customer will be put
> Hi Vic,
> I don't know if our Accounting group runs the Aged Receivables, but
correctly.
>told that we can run this while users are on the system - but you might
> We're on 407c, and it's a known bug:
> The routine is:
> 1. Admin Tools
> 2. Run Conversion Program
> 3. #9527 - Set Credit Limit Totals
> This recalculates and rebuilds the totals in Credit Manager. We were
>"cooner_55421" <cooner_55421@> wrote:
> Good luck!
> Laraine
> >server.
> > Yes...
> > I was told by tech support that a process had to be run on the
> > I can't remember the number off the top of my head."Vic Drecchio" <vic.drecchio@> wrote:
> > We run it once a week now.
> > > Vantage 8.03.408B SQL
> > > Has anyone experienced a difference in results between the Aged
> > > Receivables Report and the Customer Tracker's Financial - Invoices
> > > Aging tab?of
> > > We have a customer where we issued a Credit Memo (Misc AR Invoice)
> > > $1,000. $600 of this CM was applied to an invoice as payment infull
> > > (AR Invoice 12345 = $600). So, we still have a $400 credit outthere
> > > for this customer that is unapplied to an invoice. The CM InvoiceInvoice
> > > correctly shows an invoice balance of $400. The Shipment AR
> > > #12345 correctly shows a zero balance.instead of
> > > So we run the Aged Receivables Report for this customer and
> > > showing an AR Aged amount of -$400 it shows the entire unappliedand
> > > applied credit of $1,000. Yet, in the Customer Tracker it showsthe
> > > correct AR Aging Amount of -$400.[Non-text portions of this message have been removed]
> > > Why the variance? Am I missing something? Bug? Working as planned?
> > > Thank you in advance.
> > > Vic Drecchio
> > > TIMCO Aerosystems
> > > Greensboro, NC
> > > Email: vic.drecchio@
> > > Mobile: 704.530.3092
