Hi All,
We’ve been using Advanced MES (Mattec) for many years now. One problem we’ve always had with sample sheets / process sheets is that if you change a sample sheet for any reason if affects the data of all previous entries. Modifications to sample sheets seem reasonable over time if you were to add an inspection, remove an inspection, etc. I don’t know of a good way to revision these and keep the historical data in tact. Right now we put an NA in front of obsolete inspection lines and add new ones to the bottom, but this becomes messy. Thought I’d come here and see if anyone had any insight into how to control these changes.
