Advanced Customization of Quote Entry
OK. I've been able to accomplish part of what is required. Still,
but still I'm having trouble getting this to work: I'd like to be
able to search the quotedtl.partnumber table upon entering a
partnumber is the txtPartNumber field. If the part number exist, a
messagebox.show will display "The Part has already been quoted."
This is what I've got so far:
Private Sub QuoteDtl_AfterFieldChange(ByVal sender As object,
ByVal args As DataColumnChangeEventArgs) Handles
QuoteDtl_Column.ColumnChanged
'// ** Argument Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Dim qteAdapter as QuoteAdapter = New QuoteAdapter(QuoteForm)
Dim ohaConnected As Boolean = qteAdapter.BOConnect()
Dim Success As Boolean = qteAdapter.GetByID(txtEpiCustom1.text)
Select Case args.Column.ColumnName
Case "PartNumber"
If(Success) Then
Messagebox.show("Already entered for this part")
End If
End Select
End Sub
