Advance Planning Scheduling
APS would be capable of using labor constraints and scheduling people with
capabilities as a stand alone system maintaining it's own items and
routings, but when integrated with Vantage I don't see how it would do this.
It has to deal with the jobs as sent from Vantage and they wouldn't have
that information on their routings. APS doesn't maintain anything like a
part master in this integration that could be elaborated.
O/S Vendors are handled just as any other work center, with their own
calendars.
You can schedule maintenance time using a simple entry box on the resource
maintenance screens. It's not automated.
John
Sent: Monday, April 08, 2002 10:49 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Advance Planning Scheduling
I was just looking for the top 5 or 10 things it could do above and beyond
vantage.
Specifically:
Can it be setup consider: If employee A has 3 machines and employee B had 3
machines, when employee A is on vacation employee B can monitor all 6
machines or monitor his/her own with a setup scheduled?
Can an employee with multiple talents be scheduled where needed? Example a
critical machine will have employee B scheduled to run it when employee A is
absent/vacation.
Are Vendor Schedules or closed days considered?
Is preventative maintenance easily considered?
Patrick
Sent: Monday, April 08, 2002 9:16 AM
Patrick,
There are many detailed and inter-related fields to set up, and to list them
would be quite a job, and frankly beyond me. The Coles notes are that it is
driven by the use of WC efficiency and by "capabilities" (default from
Vantage operations) applied to each WC to set the assignment of operations
to the WCs. By making the capabilities part specific (setting up multiple
versions of an operation in Vantage - e.g. Stamp_Part_1, Stamp_Part_2), you
can control the distribution of a given part across suitable work centers in
a prioritized fashion. It considers all this to produce minimum delay or
minimum WIP schedules.
John
Sent: Friday, April 05, 2002 5:22 PM
Can you give us a list of constraints APS considers that Vantage does not?
Sent: Friday, April 05, 2002 4:08 PM
Richard,
APS is a separate product, run on a separate workstation. After jobs are
created in Vantage, manually or by MRP, that information is sent from
Vantage to APS via a manually started XML based export. APS knows nothing
about your customer demand, it strictly deals with the already created jobs
in Vantage. After APS imports this info it acts separately from Vantage to
optimize the scheduling of operations, and then exports the changes back to
Vantage. The messaging system it uses to do this can receive labor updates
from Vantage workstations, but I don't really know how this works yet.
We're just trying to get APS implemented and so far it is a very daunting
task. This may be the most intricate and counter-intuitive product of this
type that I've ever used. The sales guys use of the phrase "integrated with
Vantage" should be viewed with the usual skepticism. It's much better than
their first efforts with this product, but then it would have to be. I think
it may be of some use to our high volume repetitive production, but so far
it's bloody hard to be sure. Be very clear that you need this kind of detail
in your scheduling and have Vantage job scheduling running correctly first.
Expect to spend a fair whack of consulting dollars as well for setup and
training, the documentation provided is not sufficient to set up or run this
product. You might also want to insist on seeing a working system, not a
demo.
John A. Hannaford
Corp. IS&T
Precision Resource Ltd.
From: Richard Chuah Chong Teng [mailto:richard.chuah@...]
Sent: Friday, April 05, 2002 5:54 AM
Subject: [Vantage] Advance Planning Scheduling
Guys,
Just wondering who are using APS with their Vantage 5.1 currently? Isn't APS
a total different application from Vantage or there are tied together in
term of application? Let's me evaluate more on this: Can you access APS
while you are in Vantage application? or you need to open the APS
application and use vantage to export the data and you import the data into
APS via ODBC or others? My major concern here is how vantage work with APS
application?
Best Regard,
Richard Chuah
e-Business Specialist
Simplicity Technologies Sdn Bhd
Tel: +6 03 7880 3550 Ext. 303
Fax: +6 03 7880 3055
Mobile +6 012 488 5745
Email: richard.chuah@...
This information sent is intended only for the person or entity to which it
is addressed and may contain confidential and/or privileged material. Any
review, retransmission, dissemination or other use of, or talking of any
action in reliance upon, this information by persons or entities other than
the intended recipient is prohibited. If you received this in error, please
contact the sender and delete the material from any storage devices.
Guys,
application?
Best Regard,
Richard Chuah
Richard,
demo.
John A. Hannaford
Corp. IS&T
Guys,
application?
Best Regard,
Richard Chuah
Richard,
demo.
John A. Hannaford
Corp. IS&T
Guys,
application?
Best Regard,
Richard Chuah
Thanks John. That what I'm figure out and I can't wait to try it out to see
how APS works with Vantage. Most of the time, I'm just seeing the Epicor
doing the demo, but I want the actual hand-on to test it out.
Sent: Saturday, April 06, 2002 6:08 AM
Richard,
demo.
John A. Hannaford
Corp. IS&T
Guys,
application?
Best Regard,
Richard Chuah
<http://docs.yahoo.com/info/terms/>
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1954253.3462811.1261774/D=egroupweb/S=17050071
83:HM/A=1000239/R=0/*http://ads.x10.com/?bHlhaG9vaG0xLmRhd=1018044874%3eM=21
5002.1954253.3462811.1261774/D=egroupweb/S=1705007183:HM/A=1000239/R=1>
<http://us.adserver.yahoo.com/l?M=215002.1954253.3462811.1261774/D=egroupmai
l/S=1705007183:HM/A=1000239/rand=523368971>
Patrick,
John
Richard,
demo.
John A. Hannaford
Corp. IS&T
Guys,
application?
Best Regard,
Richard Chuah
vantage.
Specifically:
absent/vacation.
Patrick
Patrick,
John
Richard,
demo.
John A. Hannaford
Corp. IS&T
Guys,
application?
Best Regard,
Richard Chuah
