For all of you who are working with CSG extensions and CSFs for the UK and NL (and perhaps other locales). There is a step where you need to run the Script Runner or the Extension Schema Synchronize process inside the Epicor Admin Console. The processes require the 32 bit Visual C ReDist package which is not installed by default in the Server OS. It’s for SQL Server connectivity to work. Here’s the solution if you get and error that looks like this:
EpicCare KB0048776
1, close the admin console
2,go to https://www.microsoft.com/en-us/download/details.aspx?id=40784 and install the 32 bit vcredist from here
3,open the console again and run the SQL scripts
