Hello.Help,
I’m on 10.1.600.37.
I’ve successfully added the UD field to OrderMsc(_UD) table. It shows where it should in Epicor.
I’m trying to add it to the ProFormaInvc report.
I’ve duplicated the RDD. In the system RDD the UD field is not in the table OrderMsc. In my duplicate, I can see it. I make sure it is not excluded. It is not.
But in Report Builder the subreport that I need to display this UD field is in the HedMscCharge.rdl. It is not the OrderMsc table as expected. HedMscCharge.rdl uses OHOrderMsc.
In the Report Data Definition ->Report Table → Exclusions when I look in OHOrderMsc the UD field is not listed. I don’t know how to address OHOrderMsc in the RDD to have this UD field be available. This is what I need help with.
I can add the field in Report Builder for OHOrderMsc dataset query, but it errors on the UD field.
