Can anyone help on adding the SQL View in Epicor base SSRS Report from Report Builder.
If anyone has done this please share the information…
Regards,
Dhanalakshmi…
Regards,
Dhanalakshmi…
Hi, Let me know the issue or you can skype me at vishal.sharma185
When we are adding the SQL View in the report builder getting an error object not found…
Are you connecting directly to the Epicor Database or are you using the report dataset as intended?
If you aren’t using the report dataset, you are not following Epicor Best Practice (FYI). If you are, you only have to modify the SQL statement to add fields or tables.
