Adding Tables to mfgsys DB
The reason is that I would like the application to access just one db instead of 2 different db's
Ephraim Feldman
Programmer / Analyst
Axis Lighting
Sender: vantage@yahoogroups.com
Date: Fri, 17 Jun 2011 09:46:32
To: <vantage@yahoogroups.com>
Reply-To: vantage@yahoogroups.com
Subject: Re: [Vantage] Adding Tables to mfgsys DB
Epicor just updates their own tables as long as you don't have any changes
it should be fine. However the points others raise are good and you may
indeed want to be careful specially with the data corruption possibility.
Plus progress is slower than molasses going up a hill (when it wants to be)
and hard to write to. Why not use SQL or SQL Express?
*To the progress fans don't yell at me, I know it is a superior db, with
fancy functions and awesome XYZ... (it still sucks though ;-))
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Fri, Jun 17, 2011 at 9:41 AM, Mike Anstey <manstey@...> wrote:
> Yes you can do it, BUT to create a table you need exclusive access to
> the database which means you need to stop all app servers (and kick
> everyone out of the system) to do it. I usually create the table and
> required indexes in test, use the Data admin tool to export the file
> definition, the used the data admin tool again to import the definition
> to the live database usiing the "on-line" checkbox, which means you can
> do it with people still on the system.
> Once the table has been added to live, if you need to add any new
> indexes you have to get exclusive access to the database and will have
> to shut down the app servers. Indexes can't be added "on-line" for some
> reason.
> Of Jose Gomez
> Sent: Friday, June 17, 2011 10:32 AM
> It is safe, as long as you don't start adding weird dependencies and
> stuff like that. You need to use the Progress Data Admin Tool for that.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> On Fri, Jun 17, 2011 at 9:29 AM, <effgroups@...> wrote:
> > Hi all.
> > We are on epicor 9.04 with a progress database
> > We developed a external application that uses ODBC to connect to
> > various tables in the DB for read only info.
> > Now we need some more custom tables but the UD tables won't do so we
> > need to add tables.
> > I was wondering if its safe to add tables to mfgsys that will be used
> > only by the external application or do I need to create a separate
> > database for these tables ?
> > Any help would be appreciated
> > Ephraim.
> > Ephraim Feldman
> > Axis Lighting
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
- Open in Google Docs Viewer
- Open link in new tab
- Open link in new window
- Open link in new incognito window
- Download file
- Copy link address
- Edit PDF File on PDFescape.com
Hi all.
We developed a external application that uses ODBC to connect to various tables in the DB for read only info.
Now we need some more custom tables but the UD tables won't do so we need to add tables.
I was wondering if its safe to add tables to mfgsys that will be used only by the external application or do I need to create a separate database for these tables ?
Ephraim.
Ephraim Feldman
Axis Lighting
It is safe, as long as you don't start adding weird dependencies and stuff
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Hi all.
> to add tables.
> these tables ?
> Ephraim.
> Ephraim Feldman
> Axis Lighting
Thanks Jose for the quick reply.
I will not add any dependencies to existing tables I just need a storage space for data.
I have progress data admin and use it to create the tables.
What will happen when we upgrade to a newer version of epicor? Do I need to dump and reload the tables then?
Ephraim
Ephraim Feldman
Axis Lighting
Date: Fri, 17 Jun 2011 09:32:03
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Hi all.
> to add tables.
> these tables ?
> Ephraim.
> Ephraim Feldman
> Axis Lighting
While it *is* possible, consider that if the DB becomes corrupted, I doubt very much Epicor would assist in recovery if the DB structure has been altered.....
Just too easy to say whatever application you use to load data into the non vantage tables is what corrupted the db
Just my 2 cents
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi all.
> > to add tables.
> > these tables ?
> > Ephraim.
> > Ephraim Feldman
> > Axis Lighting
reason.
Of Jose Gomez
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Hi all.
> need to add tables.
> Ephraim.
> Ephraim Feldman
> Axis Lighting
*Jose C Gomez*
*Software Engineer*
E: jose@...
> reason.
> Of Jose Gomez
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi all.
> > need to add tables.
> > Ephraim.
> > Ephraim Feldman
> > Axis Lighting
- Download file
- Copy link address
Thanks for the response.
I will do it anyways in test first to make sure it works.
Never good to play in live db.
Ephraim Feldman
Axis Lighting
Date: Fri, 17 Jun 2011 10:41:23
Subject: RE: [Vantage] Adding Tables to mfgsys DB
reason.
Of Jose Gomez
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Hi all.
> need to add tables.
> Ephraim.
> Ephraim Feldman
> Axis Lighting
