Adding table to RDD
I am trying to add a table \ field to the APAgng report and have followed the instructions for adding the table into the RDD but when I try and set up the ‘Relationship Fields’ the drop down for the child table does not list the fields correctly. Any suggestions?
it is possible, hope you are missing something
We have also tried in the demo database and are experiencing the same problem. Can I ask what version you are on? We are on 10.2.300.8.
Just in case anyone has the same issue, I had missed a step:
  • Select the correct Data Source, and in the Right-Hand pane, select the ‘Exclusions’ Tab.
  • From the Main Menu, select, Actions > Include all Columns
  • From the Main Menu, select, Actions > Include all Labels
