Ok, The (3) links come over (outer Join), with an additonal link for RptLanguageID.
Ok, I just deleted the RptLanguageID link & the field(s) now populate on the form!.
Thanks for your help.
Andy
Andy
--- In vantage@yahoogroups.com, <advantage@...> wrote:
> Ok, so now in your Crystal Report, when you look at the links in the
> Database expert, did they come over that way; if not confirm them; now when
> you add your ShipTo table fields when you add the fields you need; Do you
> get that info or as you say it blanks out?
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> howecorp
> Sent: Monday, October 05, 2009 3:57 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Adding Table to Quote Form
> I Forgot to mention, this was on Epicor 9 (Ver. 504b)
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
> "howecorp" <agortman@> wrote:
> > Thanks for the reply.
> > What I am trying to do is show ship to information on the quote form. The
> current quote form only indicates the billTo or SoldTo information, it does
> not show the requested ship to address.
> > We sell to customers that ship to various branches or locations.
> > I am able to pull in one time ship to information, which works fine when
> they ship to a OTS address.
> > I do have the relationships listed:
> > quotehed.Company > ShipTo.Company
> > QuoteHed.CustNum > ShipTo.CustNum
> > QuoteHed.ShipToNum > ShipTo.ShipToNum
> > as for the Key, I just changed it to BTCustNum, still the same, I can
> browse & "see"the data, but when I place the filed on the report it does not
> populate.
> > I haven't tried a sub report yet, will try that next.
> <advantage@> wrote:
> > > What do you want to bring the ShipTo table in for?
> > > Review the relationships from the RDD to be; why are you pulling
> QuoteNum
> > > key? What fields does it give you between QuoteHead and ShipTo
> > > The relationships should be possibly: (if what you want to bring in from
> the
> > > Ship To has something to do with the Customer.
> > > QuoteHed.Company>ShipTo.Company
> > > QuoteHed.CustNum>ShipTo.CustNum? (not sure what this is)
> > > Then the relationship in Crystal, has to be confirmed; sometimes it gets
> > > broken; also depending on what you are doing; you may have to put that
> > > added table in a subreport and relate it to your main report that way.
> > > From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> [mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
> Behalf Of
> > > howecorp
> > > Sent: Monday, October 05, 2009 11:29 AM
> > > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > > Subject: [Vantage] Adding Table to Quote Form
> > > I added the shipTo customer table to the RDD for quote form. I created a
> > > relationship for the new table (parent table QuoteHed, child ShipTo, key
> > > QuoteNum).
> > > When I browse the data in the RDD (in Crystal Dev). I see the data in
> the
> > > field, however, When I place the field on the form, (either directly or
> in a
> > > formula)the field is blank.
> > > Any Idea's as to what could cause the problem? some link missing?
> > > maybe the wrong "Key" between the parent & child table?
> > > any Idea's ??
> > > Thanks
